Oil Leaks - affect performance? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 09:56 AM   #1 (permalink)
View ShellC's Photo Gallery
3rd Generation Oil Leaks - affect performance?
I have a 95 Camry DX, 120K. It's had a slow oil leak for the past year - about 1/2 qt per month. It's leaking from the front, next to the front passenger-side wheel.
My question is: Is it bad to just let it leak? Does it damage the engine and it's performance?
Thanks!
ShellC is offline   Reply With Quote
Old 04-24-2006, 10:39 AM   #2 (permalink)
View ecucio's Photo Gallery
Yes, It is bad to just let it leak. Assuming it leaking from the crank shaft or oil pump seal. It may lead to timing belt to breaks or worn faster, that will lead you to more expensive repairs.
ecucio is offline   Reply With Quote
Old 04-24-2006, 11:18 AM   #3 (permalink)
View Gary_602Z's Photo Gallery
Or if it gets worse and you don't notice it it can lead to more oil loss and engine failure. You should get it fixed.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Synthetic Oil Jaspher Camry & Solara Lounge 96 04-15-2007 12:42 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
2005 Oil Leaks 05Limited 3rd Generation (2005-2012) 20 01-24-2007 12:13 AM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 04:32 AM
Oil pressure extreme drop on 94 4Runner dutchq 4Runner Lounge 4 10-02-2004 09:05 PM
