Will these wheels fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2001, 05:14 PM   #1 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
17 x 8 Konig Tantrums off a '99 Prelude. My concern in the offset. What do you guys think :???:
Prelude Tire Info;
http://prelude.vtec.net/gen5/faq/#wheels
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 12-09-2001, 05:26 PM   #2 (permalink)
TN Legal Team
View SpectraBlueCam's Photo Gallery
Don't think so, dood! 55mm is high. Nevermind rubbing, you won't be able to install them at all because you'll hit the struts.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
SpectraBlueCam is offline   Reply With Quote
Old 12-09-2001, 05:35 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
What is offset for Cams? 38-40?
Old 12-09-2001, 10:44 PM   #4 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
If this were true then spacers would solve the problem.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 12-09-2001, 11:11 PM   #5 (permalink)
Bare backs like Tarzan
View DaksGT's Photo Gallery
Isn't hinda 4 bolt and toyota 5 I might be wrong though.
DaksGT is offline   Reply With Quote
Old 12-10-2001, 01:52 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
They won't work at all. HonDuh's are 4x100 and our Camry's are 5x114.3
"Skoolin' the unlearned!"
Old 12-10-2001, 08:46 AM   #7 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Stock offset for my 92 V6 is 38mm.
Not all honda's are 4 bolt, typically the base models are 4 bolt and the higher end models are 5 bolt. I got my rims off a Honda, and my bro's fiance's Accord V6 has a 5 bolt pattern.
Phi- the bolt pattern is correct and matches the cam but the offset is kinda high...dunno about that.
Silver Streak is offline   Reply With Quote
Old 12-10-2001, 09:59 AM   #8 (permalink)
View speedemn's Photo Gallery
You don't want to use that many spacers! 55mm is quite far from where you want to be.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 12-10-2001, 12:27 PM   #9 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
Gen5 Prelude are 5 bolt BTW..
Old 12-10-2001, 04:18 PM   #10 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
Oh well :sad:
Although most Hondas are 4x100. Preludes, V6 Accords and Oddessys share the same 5x114.3 bolt pattern. Just out of interest, other imports have 5x114.3 too (ie. Mazda, Nissan)
Thanks Guys
_________________
"Good Enuff 2B a Taxi, Good Enuff For Me!"
'92 Camry V6
-Clear Tails & Bumper lights
-Tokicko + H&R
<font size=-1>[ This Message was edited by: Phi on 2001-12-10 17:19 ]</font>
Old 12-10-2001, 04:27 PM   #11 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Integra Type R is also 5-bolts.
4Runner is 6-bolts! CRAZY...
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 12-10-2001, 10:17 PM   #12 (permalink)
View Rookie Solara's Photo Gallery
I think 8&quot; wide rims is something you already have to deal with....if you offset is larger then 40mm, that will rub the struts. If you offset is smaller then 40...you will rub the fender...but you can still roll your fender...
So, stick with this...8&quot; rims with 38mm to 40mm offset should be OK, then roll your fender...also, with 8&quot; wide rims, you need something like 225 and wider tires.
Overall, better get our own rims.
Rookie Solara
Rookie Solara is offline   Reply With Quote
Old 12-11-2001, 12:07 PM   #13 (permalink)
TN Legal Team
Correction, Howard. I have 18 x 8 with 45 offset. No rubbing.
SUPERCHARGED!
will this size wheel fit my gen 4 cam srelite23 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-29-2002 12:44 AM
steering wheel fit woshiagni Camry & Solara Lounge 7 03-09-2002 02:55 AM
