Air breather? Increase gas milage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2006, 08:33 PM   #1 (permalink)
View caveman017's Photo Gallery
I remember my driver's ed teacher telling me of some "air breather" or somthing you put on the oil cap (I believe) that helped increase gas milage, at a little cost of power (fine by me, since gas is so damn much). Any idea?
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 04-24-2006, 08:52 PM   #2 (permalink)
View Gary_602Z's Photo Gallery
Guess that is the reason he was a drivers ed teacher and not an engineer?
Gary
For better gas mileage:
complete tune-up
drive slower
proper tire pressure
drive slower
alignment
drive slower
make sure brakes are not dragging
drive slower
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 04-24-2006, 09:43 PM   #3 (permalink)
View thebluecamry's Photo Gallery
To get better mileage you have to do one thing: learn how to drive. People think automatics are just floor n go and save gas.. WRONG. Learn how to accelerate your car within 3000 rpm, know what range to let off gas to let it shift up / down, and know when you can let it coast and for how long. You will be amazed how much gas you can save.
Also, the ECT button is a no no.
Tune up, good oil, and tire psi is important as well =)
thebluecamry is offline   Reply With Quote
Old 04-24-2006, 10:42 PM   #4 (permalink)
View Gavin96V6LE's Photo Gallery
Ect
How much power does it really bring in compared to it off? it changes gear ratios? some how lol..
Gavin96V6LE is offline   Reply With Quote
Old 04-24-2006, 10:48 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
drive like a senior citizen and see the gas mileage go up (without the perpetual left turn signal on).
i compromise; i accelerate slowly but do speed = pretty good gas mileage.
Old 04-24-2006, 11:07 PM   #6 (permalink)
View YYY Camry's Photo Gallery
Is it true the faster you accelerate, the better the gas milleage? I think I read it somewhere in the forums.
YYY Camry
YYY Camry is offline   Reply With Quote
Old 04-24-2006, 11:55 PM   #7 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
yeah, learn to drive, like my camry, i especially now and i dont need to rush for any reason, wont put the rpm's any higher than 2000rpms, i keep it between 1500-2100 and its all good
MadDawg is offline   Reply With Quote
Old 04-24-2006, 11:58 PM   #8 (permalink)
MadDawg's Avatar
YEAH! i'm kidding on that, i'm being sarcastic... the faster you accelerate, the more rpm's you use, the worse your gas mileage is, thats why when you go onto trips and you use cruise control and the rpms hang around 2500rpms, you get your cars best gas mileage, so if you drive 2500rpms or under all the time, not saying you'll pull off 35mpg on the highway, but you'll get closer to 30 and thats city driving.
Old 04-25-2006, 08:44 AM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
its bad to froce shift an automatic right?
Ie you accel to 2500 then let up off the gas for a sec and then gas again.
From tests ive done personally (not in a lab...) its just good to keep your accelerations smooth and constant. Even if you hit 3000 rpms in 1st gear its not so bad, but for all the other gears keep it lower than 3000. You will notice an increase in 1 MPG vs if you go up to 4000 rpm's in 1st gear everytime.
nodrogkam is offline   Reply With Quote
Old 04-25-2006, 01:10 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
grate tips...i have a very heavy foot so i only get 25 mpg on my I4 2005 LE. I Flore it every change i get sometimes letting the rev limiter kick in . SO i guess i will try these tips to improve my mpg.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 04-25-2006, 01:20 PM   #11 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The oil breather , and later PCV valve set up was a development that reduced pumping losses for the engine where the piston had to push down against the crank case pressure for the exhaust and intake stroke, mostly due to blow by and the air inside the crank case heating up.... remember this is for engines from a long time ago. like turn of the century.
The pcv system, and in high perf engines that use dry sump, actually create a negative pressure in the crank case, but that is usually for collapsing the bubbles in the oil to reduce foaming.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-25-2006, 03:07 PM   #12 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Cruise control is a great gas saver. Obviously a constant speed over a changing speed will save you more gas, since your rpms won't constnatly go up and down. But yeah, main thing is driving slow or at speed limit.
Other things include:
-Lighten the car, less mass=less work needed, do spring cleaning in trunk and under seats.
-Use a fuel injector cleaner at least twice a year, Chevron ones are recommended.
-All the above mentioned tire stuff: rotate, balance, inflate.
-Carpool, hunt for cheapest price along your regular travel routes.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 04-25-2006, 08:46 PM   #13 (permalink)
The Other White Meat
terrastrife's Avatar
cruise control is the number 1 factor in bad milage as rpm goes up and down constantly as the crappy controller tries to keep you at the speed you want (going up and down hills etc)
i car pool whenever possible =)
also dont go on car cruises every 2nd week, LOL =)
terrastrife is offline   Reply With Quote
Old 04-25-2006, 08:54 PM   #14 (permalink)
nodrogkam's Avatar
haha nice nice.
Gas milage with tonneau??? AirForce1 2nd Generation (2005+) 10 02-17-2006 09:41 AM
F@ck Exxon Mobil-1... turbos17 2nd Generation (2005+) 62 02-01-2006 08:51 PM
Intakes and gas milage 357wheelgunner General Discussion 8 12-12-2005 11:41 AM
gas breather `d3x Hardcore Tech and Competition 3 04-11-2004 07:44 AM
Turbochargers Xenon Hardcore Tech and Competition 13 01-04-2004 08:12 PM
