V6 Valve clearance adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 01:34 AM   #1 (permalink)
this is what i say >
v-cam's Avatar
View v-cam's Photo Gallery
3rd Generation V6 Valve clearance adjustment
I have a 3vz-fe with a noisy valve. I never had the valve clearance adjusted at 160,000 kms as the mechanic said I don't need to.
So now at 220,000 kms I have a tick-tick-tick on hot idle.
To any fellow aussies out there, how much did it cost you to have the valve clearance adjusted, and did the engine have to be sent away? (one mechanic wants to send the heads away.)
Thanks.
True car enthusiasts are open-minded to everyone's creation
v-cam is offline   Reply With Quote
Old 04-25-2006, 01:57 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Yeah mine is doing the same, and am going to adjust them shortly...its making the same "tick tick tick"
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-26-2006, 07:05 PM   #3 (permalink)
View marc780's Photo Gallery
I'm not familiar with how they do things down under, V-cam. But maybe the mechanic who wanted to send your heads away is trying to sell you a valve job? Or he doesnt know how to adjust valves.
I'd check the clearances myself first. If you can get the valve covers off you can check them. Most solid lifter engines will still make noise even if the clearances are within specs. I've never owned a solid lifter engine that DIDN'T make valve noise (5 or 6 now, ive lost count). And it never did any harm, drove em all to way over 100,000 miles and then some. So i'd at least check the valve clearances first before i had it worked on. And if they are within specs leave it.
If you want to adjust them yourself you can. You just need a special service tool or one like it to push down the lifter bucket to get the shims out if need be. And a micrometer to measure the shims and a source for Toyota shims. Not easy but im guessing way cheaper than having it done.
My Haynes manual 97 thru 01 lists these valve clearances (ENGINE COLD):
4 Cyl:
Intake: .007 to .011 inch
Exhaust: .011 to .015 inch
6:
I: .006 to .010 inch
E: .010 to .014 inch
Old 04-26-2006, 07:12 PM   #4 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
1992-1996-3VZ-FE engine cold!
Intake-0.005 to 0.009 inch
Exhaust-0.011 to 0.15 inch
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Valve Adjustment -- Necessary? longfong 1st Generation (1998-2003) 4 04-09-2008 01:37 PM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
Oil Leak in 93 Camry LE 3VZ-FE V6 Front Valve Cover or Oil Pressure Switch? Xander 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-09-2005 05:27 PM
Opinion wanted on valve adjustment kjd Camry & Solara Lounge 3 04-05-2005 07:38 PM
