engine and trans swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2006, 10:31 AM   #1 (permalink)
View mjmchal's Photo Gallery
I have a 95 camry 4 cyl auto with a bad trans. I have a 92 that is wrecked with a lower mileage engine and good trans. Does anyone know of any potential problems with this swap. I have seen some documentation to the effect that there is a governor on the trans that was electronic on the earlier unit but mechanical on the later version. Does anyone know what that is all about. All advice appreciated.
mjmchal is offline   Reply With Quote
Old 04-25-2006, 01:53 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
everything swaps fine. its all the same except the wiring... you will have to use the wiring off of the 95 motor and swap that onto the 92 engine. you should also replace the timing belt, water pump, thermostat, and any other easy to do stuff while the motor is out of the car. it is much more convienient.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-25-2006, 04:57 PM   #3 (permalink)
Thanks ZONI, I kinda figured on the belt and pump. Is pretty easy when its out. Wiring looks similar but I'm sure Toyota wouldn't make it that easy. I guess I'll just have to get after it.
2nd gen engine and trans swap birddog1148 Camry & Solara Lounge 3 09-12-2005 01:13 PM
5S-FE - remove engine only? (without trans?) deddy Camry & Solara Lounge 7 08-26-2005 06:01 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
Camry engine swap HELP cato47 Camry & Solara Lounge 1 12-04-2004 10:52 PM
1990 tercel 3dr hb engine/ trans. swap 07734 Tercel, Paseo, Starlet, and Sera Forum 0 05-11-2004 04:02 PM
