HELP! Purple Stuff Coming Out Of Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2006, 09:40 AM   #1 (permalink)
*INSERT WITTY TITLE HERE*
View BlueCam's Photo Gallery
I have this purple stuff coming out of my car...i've posted about this before, but this time, i have pics.
any ideas people? its gettng more and more, and it's been pissing me off
BlueCam is offline   Reply With Quote
Old 04-26-2006, 10:43 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
could there be some shit inside the hood that maybe collects up water and leaks out purple?
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-26-2006, 10:44 AM   #3 (permalink)
Toy-Cel
TdotTercel's Avatar
View TdotTercel's Photo Gallery
where is it coming from?
It obviously cant be coming from the grill... can backtrack it to the source?
1992 Tercel DX
JDM 5EFHE, SRI, ACIS, 4-2-1 headers, 2" exhaust, Magnaflow Hi-Flow CAT
TdotTercel is offline   Reply With Quote
Old 04-26-2006, 10:44 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
take it to an exorcist, cars arent supposed to bleed.
terrastrife is offline   Reply With Quote
Old 04-26-2006, 01:15 PM   #5 (permalink)
View TRDGen5.5camry's Photo Gallery
just wondering what is the color of your coolant because what i can see is that the cap leak coolant and can you take a pic of the whole engine so i can see where else it might come from
david
TRDGen5.5camry is offline   Reply With Quote
Old 04-26-2006, 02:22 PM   #6 (permalink)
i'm not sure about my coolent color....but heres a pic of the whole engine
Old 04-26-2006, 02:25 PM   #7 (permalink)
View newbie212's Photo Gallery
Definitely check your coolant color... I use royal purple coolant in my camry..
newbie212 is offline   Reply With Quote
Old 04-26-2006, 02:26 PM   #8 (permalink)
View 97&02camryleI4's Photo Gallery
Seems to me like it's leaking out from your radiator cap. It's probably your coolant, that's my best guess so far from the pictures. But at the same time, your coolant reservoir is full so I'm a little skeptical if it really is the coolant. Did you fill up the reservoir fluid? When you open the radiator cap (make sure radiator is cooled down), is the coolant at the top near the filler neck? Keep us updated.
97&02camryleI4 is offline   Reply With Quote
Old 04-26-2006, 02:59 PM   #9 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Check if your cap is on tight, just make sure that the engine is cool and make sure to replace the fluid. (with Sunny D dave chapelle "i what that purple stuff" j/k)
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 04-26-2006, 03:36 PM   #10 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
Don't know if anyone noticed but if you look at the coolant tank, the colour
of the coolant is purple. As for the radiator cap it`s most likely broken,
any excess pressure in the coolant system is supposed to be vented to
the tank and should not be able to escape around the radiator cap itself.
I suggest you get a new radiator cap, also check the radiator for leaks while
your at it.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 04-26-2006, 04:19 PM   #11 (permalink)
i checked the color of the coolant, and it seems more of a pinkish...but i just kinda gave it a small look, i didn't have time to see it closer...i'll do that later
as for the radiator and leaks...i'm a bit of a noob...so if you could tell me how to do that...i'd be most grateful
and if i need a new cap...so be it...i'll get a TRD one just to look cool lol
Old 04-26-2006, 06:24 PM   #12 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
When u pull the cap off, where is the coolant level at. The level in the reservoir will not be an indicator of how full the system is if your cap is bad. As the heat and pressure rises, the coolant doesn't have enough room to stay in the system so it goes past a diaphram in the radiator cap and to the overflow reservoir. If the cap is not sealed correctly or if it is bad it will vent there rather than reaching the reservoir.
As the system cools down it pulls the fluid from the reservoir back into the system because there is room for it now. Once again if the seal or cap is bad, it will only draw air from the radiator cap and you will begin losing the coolant in your system. This could be why your reservoir is still full.
If upon opening the cap you don't see the fluid, FILL IT FIRST before trying to remedy your problem. Other wise you may have bigger problems on your hands. Hope this helps.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 04-26-2006, 07:07 PM   #13 (permalink)
so then is it good if there is no coolant in the resovoir?
because it was like that a few weeks ago...and i had a local shop guy put some coolant in there...
Old 04-26-2006, 07:20 PM   #14 (permalink)
No, it is not good if there is no coolant in the reservoir. There is a low and high line on the side of the reservoir. When the system is cool, it should be at the low line. When it is hot, the high line.
Old 04-26-2006, 07:37 PM   #15 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
Coolant Cap Might Be Loose!
MadDawg is offline   Reply With Quote
2000 camry engine problems help? LONG jotka 3rd & 4th Generation (1992–1996 & 1997–2001) 10 03-24-2006 10:16 PM
Smoke coming from engine. Why? kbg4 Archived Corolla threads 13 01-04-2006 03:26 PM
Need help - humming noise coming from engine meng-chieh General Discussion 3 06-10-2005 09:39 PM
Increasing Horsepower in an AE92 azpriz90 Archived Corolla threads 5 01-11-2005 07:47 PM
