Swap automatic AC controls in manual AC controlled Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2006, 01:49 PM   #1 (permalink)
View mach_y's Photo Gallery
Gen5 Swap automatic AC controls in manual AC controlled Camry?
I got my hands on the automatic AC controls for my 2002 camry. My car currently has the manual controls, and wouldn't you know it, the plugs are different
So, I have a spare manual control set too... I am thinking of taking the connector out of the that one, and wiring it to the inputs on the back of the automatic controls, so I can then plug in the automatic AC controls, without touching the stock wiring.
Good idea / bad idea? It looks like there are the exact same number of wires going into both, so it should just be mapping them over to the right spots... is there a chance I could fry something other than the automatic AC controls? I looked at the wiring diagrams posted (thanks whomever did that), and am having a hard time decyphering them.
Any help / advice? Thanks!
Mark
mach_y is offline   Reply With Quote
Old 04-26-2006, 02:00 PM   #2 (permalink)
View jurisprudent's Photo Gallery
I confess I don't know Toyotas at this point, but I would imagine like any other car I've had this on, aren't you lacking the sensor input that allows the automatic climate control to know when to come on and when not to? I just don't see how this could work in automatic mode without it.
jurisprudent is offline   Reply With Quote
Old 04-26-2006, 02:47 PM   #3 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
There is a seperate computer, I believe.
drunken_panda is offline   Reply With Quote
Old 04-28-2006, 07:51 AM   #4 (permalink)
I opened up the automatic controls, and it looks like the sensors are built in. Anyone else?
Old 04-28-2006, 11:11 AM   #5 (permalink)
Iron Chef IV
I believe there should also be a sensor on the dash. I took a quick look at the FSM and there are some parts that are different b/w the Auto and Manual AC.
Old 04-28-2006, 02:08 PM   #6 (permalink)
jjthenovice's Avatar
View jjthenovice's Photo Gallery
He's correct, there is a sensor on the dash.
jjthenovice is offline   Reply With Quote
Old 04-28-2006, 03:55 PM   #7 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
There is a temp sensor that needs to be retrofitted as well. For the amount of work involved, just go buy wheels dude!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 04-28-2006, 06:22 PM   #8 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
werrd on the wheels!
johnnyzee is offline   Reply With Quote
Old 04-28-2006, 06:37 PM   #9 (permalink)
Lurker Supreme
View Sharky3's Photo Gallery
2 threads on this after I searched looks like it isn't possible without lots of work. http://www.toyotanation.com/forum/t29468.html
http://www.toyotanation.com/forum/t19364.html
2002 Camry LE
Sharky3 is offline   Reply With Quote
Old 05-02-2006, 09:27 AM   #10 (permalink)
not much money involved seeing as I already have the controls I could get a temp sensor from a crash lot. I read through those threads too... can anyone look at the FSM and confirm needing a different servo motor? Part number? Thanks
Old 10-13-2006, 12:33 AM   #11 (permalink)
The Naive Voice of Reason
thapranksta's Avatar
View thapranksta's Photo Gallery
Bump. What happened with the swap?
Old Car: '03 Toyota Camry LE
New Car: '04 Black ES330 (Aftermarket sound/navigation system installed)
Always got something else in mind...
thapranksta is offline   Reply With Quote
Old 10-13-2006, 08:25 AM   #12 (permalink)
2003 Camry Speedster
View IPDaily's Photo Gallery
yeah i agree, it's probably a lot more involved than it seems... i don't think simply rewiring the stock computer to the automatic controls would do it... don't forget the automatic climate control has a thermostat and the manual doesnt... so that would require a temp sensor and possibly having to reprogram the on-board computer... it just seems like more work than its worth...
IPDaily is offline   Reply With Quote
Old 10-15-2006, 05:32 PM   #13 (permalink)
Has anyone actually tried it and can anyone confirm that the sensor on the dash is actually for the auto climate control? Maybe the temp sensor is built in. I just ask because no one ever verified anything.
Old 10-15-2006, 06:11 PM   #14 (permalink)
Gen6
Yes the sensor on the dash is part of the climate control. Also, if you look just below or around the key ignition there are some little slits (openings) and behind it is another sensor for the clilmate control. I found this out by reading the service manuals.
2012 XLE V6 Magnetic Grey Premium HDD Nav Smart Key
Old 10-15-2006, 06:15 PM   #15 (permalink)
Well I guess that means no way, no HOW, NO CAN DO!!!
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
GEn 2 Automatic to Manual Conversion phat91camryLE 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-28-2002 05:56 AM
Celica or Camry Swap, need Some votes please ! TruBtc Celica Forum 4 08-28-2002 02:25 PM
Celica or Camry Swap, need Some votes please ! TruBtc Camry & Solara Lounge 4 08-20-2002 02:53 AM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
