Adding ABS module to non-ABS Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2003, 02:14 AM   #1 (permalink)
View BoogieMan's Photo Gallery
Is it possible to get an ABS module from a camry and put into another that doesn't have ABS?????
Does it require anything else??
1995 4-cyl
Thanks!
BoogieMan is offline   Reply With Quote
Old 02-14-2003, 08:23 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
I don't think it's a simple task, there are ABS sensors on all 4 brakes, hubs are also different, read the Haynes manual and you'll get the idea.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 02-14-2003, 09:04 AM   #3 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
not to mention fuses, ecu, hydraulic lines, brackets, axles, etc... and dont forget the rear brakes too. 4-cyl abs models had rear discs, which you may not have.
ratko.org
Ratko is offline   Reply With Quote
Old 02-14-2003, 09:40 AM   #4 (permalink)
hehe I thought So!
What do I need to upgrade the brake system? to Rotors? how much of an expense is it?? and does this require mod to every other component?
I'm sure there's a threat already that will help...
