Slight Shudder When Coming to a Stop... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2006, 01:54 AM   #1 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Gen5 Slight Shudder When Coming to a Stop...
I've noticed a slight shudder when coming to a stop. This doesn't happen always, and it only happens if I'm coming to a "normal" stop - meaning not barely touching the pedal, but not stomping on it either. Brakes feel fine and when I got my oil changed they inspected the front discs and rear drums and it checked out okay.
Any ideas what it could be? I can't remember either way if this was happening before they inspected my brakes..
- '05 I4
- 15,750 miles
- Oil changed regularly
- Tires inflated properly, no excessive/weird road noise
- Fluids are clean
- Invoice says: "Brake inspection.. Remove and reinstall four wheels and rear brake drums to inspect brake condition. Inspect entire system for leaks. Brake system ok during inspection."
Thanks
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 04-28-2006, 02:01 AM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Its your transmission shifting back into 1st gear.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 04-28-2006, 02:07 AM   #3 (permalink)
Really? It lasts for 3-4 seconds.. I've never experienced this on another car and I've driven plenty.
Old 04-29-2006, 12:57 AM   #4 (permalink)
View mkII's Photo Gallery
That sometimes happens to me when I make a stop on gravel or sandy areas.
i miss my mkii.
Gen 5 - 2002 Phantom Gray Pearl Camry V6 LE:
-TRD Rear Sway Bar
-SE Model Strut Tower Bar
-Borla Exhaust
-Injen Intake
-Sportivo Grille
-TRD Lowering Springs (sitting in my room waiting to be installed)
mkII is offline   Reply With Quote
Old 04-29-2006, 01:38 AM   #5 (permalink)
If that were the case, that would make sense since the ABS would kick in..
I noticed it again today, while going through a McDonald's drive thru. I was already in first gear, rolling along and I could feel the car shaking just a bit while coming to a stop. Ah well - maybe I'll have my cousin drive it and see what he thinks. He's still in the process of getting into auto mech but he's been right on with other things in the past.
Thanks
Old 04-29-2006, 01:58 AM   #6 (permalink)
zZzZz(-.- ) -----o(^.^ )o
halfad0ubleace's Avatar
View halfad0ubleace's Photo Gallery
umm, is it right before your car comes to a stop or is it also while your car is just slowing down in general? im afraid i wouldnt really know what to tell you about automatics though. i used to have that awhile ago, but it was because i had a bump in one of my rear tires and i had to get that replaced.
halfad0ubleace is offline   Reply With Quote
Old 04-29-2006, 11:27 AM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I don't know if this is possible but can you disconnect the ABS system on a Camry? I understand that you can on most vehicles and it will eliminate the ABS system and return you to "standard" brakes. If you do this and it quits vibrating it would suggest that your ABS system is acting up.
Kep
Old 04-30-2006, 10:30 PM   #8 (permalink)
t^3
Formerly Mad Scientist
View t^3's Photo Gallery
I think I have the same thing too, but I don't have ABS. It only happens once in a while, so I really don't know what circumstances allow for it to happen.
t^3 is offline   Reply With Quote
Knocking/ thumoing noise coming from suspension? PoR2GeEzCamry Camry & Solara Lounge 7 12-21-2007 10:29 AM
whine/chirp noise coming from engine block...bearing?? shackelton Camry & Solara Lounge 4 09-16-2004 02:23 PM
more intake questions...they just never stop coming mkeye2daem Camry & Solara Lounge 1 06-05-2004 02:54 PM
HELP..weird squeaky sound coming from tires Tubbyc Camry & Solara Lounge 6 04-20-2004 01:35 AM
HERE'S SOME PICS OF HOW EVERYTHING IS COMING TOGETHER turbomaster Archived Corolla threads 3 08-14-2002 11:56 AM
