engine flush neccassary? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2006, 02:04 AM   #1 (permalink)
View jmp0126's Photo Gallery
3rd Generation engine flush neccassary?
Hi people!
I have a 95 camry v6 with 65,800. I'll be switching over to synthenic oil on my next oil change. Is it neccassary to flush the engine first before hand?
Thanks for your answers.
jmp0126
jmp0126 is offline   Reply With Quote
Old 04-29-2006, 04:23 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
nope, not at all
just do oil changes as you noramlly would- after a number of oil changes, you'll be running 100% synthetic
HaHa
Old 04-29-2006, 08:19 AM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
also, a lot of times, flushing an engine can do more harm than good. it'll break loose any coked up oil and such that's holding any leaks from happening. most notable are valve guide seals. i just dont care for the stuff personally. i would just do the oil change and like eye8pussies said, after a few changes, you'll be totally synthetic.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 04-29-2006, 12:17 PM   #4 (permalink)
Thanks guys! I'm still going to change the oil every 3000 miles when I switch to synthenic.
Old 04-29-2006, 07:55 PM   #5 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Just switch whenever you want. Flush not needed.
Meh, I do a flush every once in a while to see what goodies fall out.
If its garbage stopping a leak, I would rather it came loose and out then have it plug up an oil passage somewhere. I would rather change gaskets.
A lot of gaskets will fail over time in a car. Heat and constant expansion/contraction will break rubber up. Just the facts of life, it does not matter what you have - it will leak eventually.
176K on mine and other then it's gas consumption (driver's fault) - I dig it.
old faithful
amerikim is offline   Reply With Quote
Old 04-29-2006, 08:02 PM   #6 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
it woudlnt be necessary to change to synthetic and pay 3-4 more dollars per quart of oil if you're just going to change it just as often as regular dyno oil.
synthetic oil is thinner and may cause leaking anyways (besides an engine flush).
Ive done flushes and used all kinds of oil with no problems on my 90K car.
Right now i am using synthetic blend and i am perfectly happy with it. It can last up to 7500K but i'll change at 5. At 3K using a bosch filter, the oil looks pretty darn clean and its only begning to turn yellow. And keep in mind i drive hard. Changing synthetic at 3K really is a waste. Our new highlander has fully synthetic from mobil 1 with their filter. We will change in 12 months or 10K. It says 12 months or 15K...but 15K is just too much for me.
So think about it. If you're wallet is that big, then by all means do as you wish, but i'm just saying what you want to do is unecessary. For a camry i think Synthetic Blend is awesome stuff.
nodrogkam is offline   Reply With Quote
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
3SFE Engine Technical Information please help. rav4uk Hardcore Tech and Competition 2 07-09-2006 06:39 PM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 04:09 PM
