Gentex Homelink Mirror - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2006, 10:03 PM   #1 (permalink)
*INSERT WITTY TITLE HERE*
View BlueCam's Photo Gallery
I'm getting one of the gentex mirrors with compass and temp and map lights as one of my graduation presents. I see no reason for it to not work in my 98 4cyl LE.
However, there could always be something i didn't think of....so i'm asking you guys...
It should work...right?
BlueCam is offline   Reply With Quote
Old 04-30-2006, 09:31 AM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
It should...
Although when I bought mine on Ebay the seller needed to know if my Camry was a 97-99 or a 2000-01. I'm not sure if there are significant differences.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 04-30-2006, 11:37 AM   #3 (permalink)
Originally Posted by 98CamryLE
It should...
well, judging by your name, you've got a 98 le, like me, so did it fit?
Old 04-30-2006, 10:28 PM   #4 (permalink)
Camry Freak
98CamryLE's Avatar
Yes, mine fit perfectly- but apparently the seller shipped me the "97-99 specific" version.
I can't imagine it would be much difference. I just had to tap into the wire that connects to the radio under the dash, run the wire up the A-pillar, then up underneath the headliner.
It should come with pretty specific instructions. Here's some info from a post I made here in 2005:
For my 1998 Camry:
-Carefully remove original mirror.
-Remove sunvisors, which allows you to slightly remove very front of headliner.
-Remove A-Pillar trim on driver's side.
-Remove trim under stearing wheel, and trim near the doorjam
-You splice into the wire that comes off the ignition switch (that turns on the radio and other stuff that comes on when the key is in the 'on' position.
-The wire runs from under the steering wheel, up the driver's a-pillar, into the headliner, and then down the center of the windshield to the mirror, behind the small little trim piece that comes with the mirror.
I think mine took like a hour or so to install, maybe a hour and a half.
Enjoy. It's a cool little accessory.
2007 Camry Hybrid
Homelink mirror Pb 2nd Generation (2005+) 151 06-14-2009 11:59 PM
I bought a gentex homelink mirror and the Toyota tech told me......... SinCityTaco 2nd Generation (2005+) 4 01-03-2006 05:39 AM
'93 driver broker mirror & bracket total1 3rd & 4th Generation (1992–1996 & 1997–2001) 6 11-20-2005 12:16 PM
HomeLink Mirror Count 2nd Generation (2005+) 3 11-02-2005 01:47 PM
Homelink Mirror wilddawg 2nd Generation (2005+) 1 09-21-2005 09:28 AM
