FM transmitter in Camry doesnt work? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2006, 10:46 PM   #1 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
I was going to buy an FM transmitter for my ipod to use in my 2002 Camry. The salesperson told me that it will not work in newer cars with no antennae. I disagreed, but he said he's 100% sure about this. He said the signal hits the windsheild and goes nowhere . I found it hard to believe and left the store.
So, is this true?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 04-29-2006, 10:53 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Hmm...well AFAIK, your stock radio picks up signals in the FM band just like any other car/radio/stereo/whatever....so if there is a device that is emmitting a low FM band signal, like an IPOD radio adapter, surely it will pick it up. I tend to disagree with the saleperson. New cars are not "sheilded" by RF!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 04-29-2006, 10:57 PM   #3 (permalink)
2002 Camry
Yes, I agree. Besides, the radio is inside the car. i guess I'll buy it from somewhere I can return if it does work.
Old 04-29-2006, 11:33 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Sounds like BS to me also. I don't see any reason why it wouldn't work.
The antenna on the rear window should pick it up.
I guess go get one somewhere local with a decent return policy.
2007 Camry 2.4L 5M
Old 04-30-2006, 12:23 AM   #5 (permalink)
View caveman017's Photo Gallery
BS, my dad has one in his audi.. no antenna for his car
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 04-30-2006, 12:41 AM   #6 (permalink)
camry "durabilty" tester
View brownyy's Photo Gallery
that anternna cable has to run form the anttenna to your head unit somehow... it will work, i made my own one day, sat in car and used it, works fine... and mine was a poxy home made thing...
brownyy is offline   Reply With Quote
Old 04-30-2006, 02:14 AM   #7 (permalink)
The cable that runs from the antenna to the HU is shielded.
2007 Camry 2.4L 5M
Old 04-30-2006, 02:23 AM   #8 (permalink)
View .tony. .riot.'s Photo Gallery
I call BS.
.tony. .riot. is offline   Reply With Quote
Old 04-30-2006, 02:25 AM   #9 (permalink)
View sumptimwong's Photo Gallery
I believe the antenna on the gen5 is in the rear window. Should be the top few horizontal lines, just above the rear defroster. I don't see any reason why a FM transmitter wouldn't work.
sumptimwong is offline   Reply With Quote
Old 04-30-2006, 02:55 AM   #10 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
I used an FM transmitter in my '02 to play my satellite radio until I hardwired it. Works fine. That guy is a moron.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 04-30-2006, 08:29 AM   #11 (permalink)
View netherland24's Photo Gallery
fm transmitter sometimes sound shitty . GET a FM modulator. i think u can use a AUDIOVOX FMV1000 something like that they sell them at circuit city for 50$ and usually charge 25$ to install and u hook it up too the headphone jack and it sounds MUCH better. jus thought i let u know other options. or if there is a uss spec's offers aux inputs for factory radio.
01 Camry SQ project
netherland24 is offline   Reply With Quote
Old 04-30-2006, 03:36 PM   #12 (permalink)
MAKE ME A TACO!
BigIke's Avatar
View BigIke's Photo Gallery
I used the FM transmitter built into my sirius unit and it worked ok but sometimes even weak stations would over power the signal so i got the FM modulator and it worked much much better
so yah spend a little more and get a FM modulator with a on/off switch
BigIke is offline   Reply With Quote
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
Low fan switch doesn't work on 90 camry bpoppe4 1st & 2nd Generation (1983–1986 & 1987-1991) 19 10-04-2007 12:24 PM
2000 Camry SW Enquiries riko666 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-18-2006 11:19 PM
A/C dont work with new Dash, Camry Forum is clueless ? ? ? avalon01 Audio, Video, and Security - Tech 16 08-29-2005 09:11 AM
please help 89 camry wipers don't work disenchanted 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-01-2004 12:35 PM
