My LED light conversions in Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 12:52 AM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
4th Generation My LED light conversions in Camry
I ordered a few LED bulbs from ebay and some websites, tried to have a cheaper improvement in lights. As many know, LEDs draw less power and is supposed to last longer as well. Except they aren't recommended in turn signals because they draw less power, and it'll cause the turn signal to flash faster.
My experiences:
Stop Brake Light - Don't do it, a sharper color, but not as bright as stock.
Back Up Light - Not nearly as bright as stock, it has a dim Xenon White color.
Tail Light - Not a huge improvement, almost the same brightness, but a bit sharper red color.
Rear Sidemarker - Not too noticeable, just a sharper red color again.
Interior Dome and Map lights - A pretty big improvement, highly recommended if you like the Xenon White, Blue, Red, or whatever color of your choice on the inside. Looks almost as bright as stock, but the color makes it all the cooler.
Trunk Light - Probably not too recommended unless you find a LED bulb that spreads the light out at a wider angle, it's too concentrated in a circle.
Glove Box - Couldn't change it, I'll have to remove the glove box, probably will do it later.
Front turn signal - Will buy Syvlania 1157AST eventually for it.
That's about all the possible lights to change out in a Gen4 Camry, except for instrument cluster and dash lights. I'll probably show pictures of the interior lights, because the exterior lights didn't show a huge improvement at all.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 04-30-2006, 06:35 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
next time go to an electornics store and buy 6 or 12 volt LEDs with MASSIVE MCD output (they are 10-20mm in diameter), not those little 3 volt clusters =) and retro them in ^^
terrastrife is offline   Reply With Quote
Old 04-30-2006, 09:16 AM   #3 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
LED's work fine as turn signals as long as you put a resistor in line or if you have a properly designed LED array with the proper resistance.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 04-30-2006, 12:32 PM   #4 (permalink)
2GR FTW
darksparkz's Avatar
Couldn't find a good camera, pictures are a bit bad because of dark photos.
Left bulbs are all LEDs, right bulbs are all stock. Well in the picture with the reverse light on, the left bulb is stock too, just that its newer, so its a bit brighter.
Old 04-30-2006, 06:25 PM   #5 (permalink)
View leasaunce's Photo Gallery
nice, which LED bulbs did you buy for the brake light? got pic of them?
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 04-30-2006, 07:12 PM   #6 (permalink)
View AyzhenInvasion's Photo Gallery
iunno about the trunk light bro. but thumbs up for everything else. nice work
for the trunk light, u could get a led straight array and double side tape it up there somewhere that way it won't be a spot. if u don't do it right, it'll be a strip of light so maybe but the leds in some kinda tube to spread the light. just an idea. or u could get a cold cathode from ebay =D
AyzhenInvasion is offline   Reply With Quote
Old 04-30-2006, 08:39 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
I meant that left brake light as stock. It's just a new housing that got replaced, so the bulb itself looks a bit brighter. I tried the LED on the brake light, it was a 3157 25-LED Red bulb from www.superbrightleds.com, it was really dim, much dimmer then stock.
Yeah, I'll probably need a cathode tube for the trunk, the little LED bulb isn't that great in it.
Old 04-30-2006, 08:47 PM   #8 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
what size is the map light?
WhiteRabbit is offline   Reply With Quote
Old 05-01-2006, 03:44 PM   #9 (permalink)
View AmanO's Photo Gallery
I have done the same thing (pretty much) and this is my conclusion.
For the fron and rear turn and brake....use LED bulbs that throw light to the side. They lookl like a tower and have 5-8 on top and 15-20 on the sides.
For the trunk anyone who has done it here will tell you that a cheap CCFL set for less than 10$ is SOOOOOOOOOOOO much brighter and is an extremely easy mod. I even did it withough cutting any wires.
The license plate and reverse lights use the flux refractor 5 LED bulbs that I have used in the dash (white, so did leasaunce i think) and Snakeyes has too (red) They are not quite as bright but last long and have better color.
For the reverse, I want to find a easy/non reversable way to put 1156 or 3156 bulbs in there. Also clearing the lense would possible be good. (Any one do that?)
Reading and dome lights are an easy swap but I found that even the 9led ones off of Ebay were lot bright enough for me. I have 2 9led bulbs in the dome and I am sure I can fit 3 or more 9led ones in the map. I also put a 9led in the vanity lights but I need to do some dremmeling (its a verb right?) to get it in (and I broke the screw threads on the visor itself so be carefull taking it off)
I am using a cheap 1led bulb for the rear markers and 2 red 5led flux refractors for the running lights.
If i remember correctly the map light is a 44mm festoon http://cgi.ebay.com/1pc-Festoon-Dome...QQcmdZViewItem
This is the guy I get as much as possible from. Cheap prices and shipping (though the shipping takes a little long)
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 05-01-2006, 04:32 PM   #10 (permalink)
2GR FTW
darksparkz's Avatar
Yep, that's the same ebay guy I order my LEDs from.
The front map light is 44mm, and rear courtesy/dome light is 31mm. I got 9LEDs for both 44mm and 31mm.
Using LEDs on the brake light casuses the brake sensor to light up on the dash, and I think using LEDs on turn signals would cause the flashers to flash really fast. I may consider looking around for the "tower" brake LEDs like you stated, but might not want to mess with the turn signals unless I find a resistor for it. Might be a better idea to just stick with Sylvania 1157AST for signals.
What's a CCFL set? Is it a cathode tube set? Any recommendations on what kind to get on ebay or a website? And how would you hook up a cathode tube set?
Old 05-01-2006, 04:56 PM   #11 (permalink)
Yes CCFL is cold cathode. Check this guy http://stores.ebay.com/Get-Rid-of-It
or www.svc.com
I like the turn signals flashing fast but I do not like the noise (no matter how fast) how can I get rid of that? Are there relays that you can adjust the speed but are silent? Can put some sound deadening shit around it or is that hazardous?
My brake light warning does not light up. Something is up with yours...which LEDs did you use?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Here are the front turns I am gonna get...anyone useing them (or similar?)
Here are the stops
Old 05-01-2006, 05:26 PM   #12 (permalink)
2GR FTW
darksparkz's Avatar
http://www.svc.com/clk15wt.html
Would that be easy to install on a car's trunk? I'm not quite sure how to wire that for it to work. I would like something sound activated that can follow the beat to music.
Old 05-01-2006, 06:29 PM   #13 (permalink)
Yea..i think the installation would be the same. The only thing is, i think you would get more light from a dual 12inch set at the same price.
Unless the main point is the sound activation........but then I would not do white.
Old 05-01-2006, 06:43 PM   #14 (permalink)
TN's furry friend
anyone know the size of the map light for a gen 3.5?
Old 05-01-2006, 07:04 PM   #15 (permalink)
2GR FTW
darksparkz's Avatar
Yeah, I just thought about it and white seems plain, I'll probably go blue.
Try removing the dome light with a flathead screwdriver, but be careful to try not to scratch the plastic around it. Just measure the length of the bulb down to the milimeter and your set.
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
98 camry le v6: Trunk Lid light/ Back up lights not working, Problem and solution ihqazi 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-26-2009 01:01 AM
99 Camry problems--check engine light, engine rattle, help? Ranger X Camry & Solara Lounge 12 05-24-2005 12:57 PM
Camry 96 warning light toyotacamry96 General Discussion 3 09-29-2004 12:37 PM
'95 Camry XLE with oil light/ speedometer issue aeonnfluux 3rd & 4th Generation (1992–1996 & 1997–2001) 6 06-27-2003 09:53 AM
