Originally Posted by atobe
thanks 88LE had to draw a picture to make sense of things and your parts worked mine didn't
No prob.
Where you went wrong, was with this fitting: Stainless steel 1/8npt (F) to 1/8bspt (M) pn: 4092k11
The BSPT end on that works out, it screws in the cylinder head. However the NPT end is female, so it won't screw into the T which is also female.
You can't screw 2 female threads together (no pun intended).
This fitting is not really necessary: stainless steel 1/8" NPT male to 1/8" BSPT female (4092K26).
1/8" NPT and 1/8" BSPT are really close. One has 27 threads per inch and the other has 28 threads per inch.
So you could wrap teflon tape around the threads on the oil pressure switch and screw it into the T.
Its better to use that fitting as the threads match up exactly, but its up to you.
I can't believe how much that fitting costs though. The price is just as bad as AN fittings and hose ends.
