front wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 08:59 PM   #1 (permalink)
View MIKEBRAWN1's Photo Gallery
2nd Generation front wheel bearings
Hey guys I did a search and didn't find anything about it so here goes. Has anybody changed out their front wheel bearings and if so how did you go about getting the bearing out of the knuckle?? I can pull the knuckle but have never pulled out this kind of bearing before so any help would be greatly appreciated.
MIKEBRAWN1 is offline   Reply With Quote
Old 04-30-2006, 10:03 PM   #2 (permalink)
Sebastian Loebs evil twin
BakaWill's Avatar
View BakaWill's Photo Gallery
ok, it sounds to me like you are talking about cv joints. if you are gonna work on cv joints you mindas well just change the axel its kinda less of a headache. i would go to advance or pepboys and get a haynes manual for your car as it can explain everything in greater detail than ppl can over the internet.
1990 camry dx 3s-fe
BakaWill is offline   Reply With Quote
Old 04-30-2006, 10:45 PM   #3 (permalink)
View pcgeek's Photo Gallery
You gotta use a hydraulic press to do it right. Pull the hub then take it to a garage and have them press the old one out and press the new ones in. Reinstall hub. Align the front end.
pcgeek
pcgeek is offline   Reply With Quote
Old 05-01-2006, 01:59 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ What he said.
Instead of replacing the bearing, you can replace the entire knuckle. Pull one from a junkyard, but make sure its good.
For me it ended up being easier and cheaper then buying the bearing, seals, and having it pressed in/out.
"Skoolin' the unlearned!"
Old 05-01-2006, 02:15 PM   #5 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
On my old dodge minivan (smililar layout) the parts store had rebuilt knuckles available, which cost about 25 or so dollars more than the front bearings that they sold, as long as the used knuckle assembly was returned for the core. Then I would have to install new dirt seals on the CV Joint side as well.
I only found out after I hammered one bad bearing out to take to the store to compare.
If you choose to press in the bearing yourself, be sure to use high pressure grease in the bearing seat.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
front right wheel suspension rattle chesstompowell Camry & Solara Lounge 60 01-25-2007 05:52 PM
Hiss from the steering rod that connects to front wheel Corbett Archived Corolla threads 0 09-08-2002 11:04 PM
