Originally Posted by greeneclipse
Hey everyone,
A few quick questions about some suspension work on my '99 camry V6:
1)what brand struts/shocks should I buy to keep the factory ride?
2)what brand strut mounts should I buy (all mine are rattling like crazy)?
-I've heard that some brands are preferred over others as to the fitment.
3)where is the cheapest place to get these parts (online) ?
thanks all for your input
As others have mentioned, the KYB strut mounts from Tirerack should do the trick and take care of your "clunk" sound. (Is it only when you hit bumps in the road and maybe even when turning?) If you want a more 'factory-like' suspension feel, I've also heard the KYB struts are a decent choice. Personally, I don't like the factory (a.k.a. Squishy) ride so I used KYB mounts, Tokico HP Blues for stiffer struts, and Eibach Pro-kit springs. You didn't mention how many miles your 99 Camry has or the condition of the springs, but it's a lot easier to change out all of these parts at the same time. I know... costs more money.
My gen 4 ('98 5SFE) had a little over 100k miles when I changed the suspension. 18000 miles later, no problems and I'm still amazed at the improvement it made in handling. (I also added a strut tower brace.)
As for where to get the parts, Tirerack is an excellent company - there are probably others out there in the online world that others use reliably. Stay away from the Toyota parts department as much as possible unless you like to throw away money. NAPA is another source I use with good results.
Special tools: You will need a set of strut spring compressors, which you can borrow from Autozone (or other parts store?). Autozone just keeps a deposit until you return their tool, then returns your deposit. I'm assuming you already have a breaker bar and a torque wrench or two. Be safe.
