cv shaft bolt head stripped - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2006, 07:44 AM   #1 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
this is a problem. last night when i was removing the bolts that hold the cv shaft on, i discovered that three of the allen type heads were stripped. this was done prior to me working on the car. they were 8mm heads and now they're...uh round. the car is a 92 with the 3vz and a 5 speed. i suspect a similar problem will rear its ugly head on the passenger side. if i cant get those bolts out, i cant change my clutch. i considered cutting the heads off and then with heat and a small pipe wrench, turning the "stud" out. any thoughts or suggestions ould be most appreciated.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 05-02-2006, 07:58 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
This wont help that problem...but, if you want to change your clutch...just pull the entire shaft out from the gearbox. Its the way ive done mine.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-02-2006, 08:26 AM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
if you have a dremel or a similiar rotary tool or even a hack saw, notch the top of the bolt so you can use a flat-head screwdriver.
LE05 is offline   Reply With Quote
Old 05-02-2006, 08:27 AM   #4 (permalink)
mazdaverx7's Avatar
i wasn't sure if it was splined and had a circlip on the other end like a "normal" cv shaft. i was thinking it was like an audi i had and the cv was held on strictly by allen headed tye of bolts.
85 RX-7 GS 5spd
Old 05-02-2006, 08:29 AM   #5 (permalink)
mazdaverx7's Avatar
i had considered that but the bolts are VERY tight. i had to use a small cheater pipe on the handle of my wratchet to get the other bolts loose while the wife stood on the brake pedal. im not sure if this would work. i did consider it though. i have some big flat heads.
85 RX-7 GS 5spd
Old 05-02-2006, 08:29 AM   #6 (permalink)
VeeZed
One (the shorter one) has the small circlip on the end...but its simple to the shaft out...you just need to tap it out .. it will disengage no problem. The two methods ive used is to tap it with a rubber hammer from under the car....or use a pole from the top of the car and tap that with a hammer...Make sure you drain your gbox oil first of course
Old 05-02-2006, 08:32 AM   #7 (permalink)
mazdaverx7's Avatar
what would i tap on? the shaft itself? there isnt a lip on the shaft near the gearbox to tap on. i would definatly do this though!!!
85 RX-7 GS 5spd
Old 05-02-2006, 09:06 AM   #8 (permalink)
VeeZed
In this pic of a drive shaft....
You can see on the right hand side...thats the spline that engages into the gearbox.
I just tap the larger section a bit further left of it....you can't miss it.
Note...not a Camry drivshaft picture hehe
Old 05-02-2006, 04:22 PM   #9 (permalink)
mazdaverx7's Avatar
ok, that makes sense. i can do that. if the passenger side bolt heads are stripped, i think i'll have to cut the heads. thank you for the advise!
85 RX-7 GS 5spd
Old 05-02-2006, 10:03 PM   #10 (permalink)
mazdaverx7's Avatar
i should throw up a pic tomorrow to show clearance issues.
85 RX-7 GS 5spd
Old 05-02-2006, 10:13 PM   #11 (permalink)
View Gary_602Z's Photo Gallery
Irwin makes a female type easy-out. Go to Auto-Zone and pick up a set they work wonders!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 05-03-2006, 07:38 AM   #12 (permalink)
mazdaverx7's Avatar
using thosewould be tough. the bolts are hardened and it would be difficult to drill them to fit the easy out in the pilot hole. but, it is always an option.
85 RX-7 GS 5spd
Stripped Torx T-30 bolt heads -- any fix? whodaguy General Discussion 3 03-20-2006 01:11 AM
3E-E stripped head bolts. Any suggestions? izekat Tercel, Paseo, Starlet, and Sera Forum 7 05-01-2005 08:02 PM
Stripped transmission pan bolt. jefe Camry & Solara Lounge 6 11-14-2004 04:35 PM
Stripped bolt SuKnSin Camry & Solara Lounge 1 05-13-2003 06:11 PM
OH NO! ... stripped a bolt ek-9 Archived Corolla threads 13 07-21-2002 02:59 AM
