Throttle Position Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2006, 08:01 AM   #1 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
A while back my car threw the code for the Throttle Position Senor. It reset itself the next day but I still went to run the code at Autozone to see what it was. What are some signs of a bad sensor? The only thing different I've noticed it sometimes in second gear I'll push down on the gas and the rpms will go up while the car is accelerating but the rpms go up faster than the car is accelerating. Make sense? Some advice? 88LE, etc? Thanks Jon.
JMSinMD is offline   Reply With Quote
Old 05-03-2006, 08:26 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
rpms increasing without vehicle's speed increasing is usually a sign of a slipping clutch in a manual trans and a worn clutch pack in an auto trans. a bad tps will give you a fluctuating idle in neutral and could lead to some surging when driving. you can adjust the tps. when do the rpms increase? what speed, what gear?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 05-03-2006, 03:04 PM   #3 (permalink)
View Gary_602Z's Photo Gallery
Sounds more like a tranny/clutch problem than a TPS. You should be a ble to check the TPS with a voltmeter.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
