Brake Disc Rotor Seized on Hub
I was replacing my worn brake pads and also wanted to replace the front disc rotors at the same time. Pads (Hawk Performance) were no problem, the rotors on the other hand - big problem... I cannot get those puppys off! (P.S. I have 118k miles on this car.)
I've seen some posts on this topic, but wanted to learn how others have dealt with this problem.
What I've tried so far...
- Had both front wheels off and on jack stands, so I could rotate the discs
- Removed the calipers and torque plate. No extra holes in these rotors to help with removal.
- Used Liquid Wrench in the lug nut areas and around hub... overnight
- Next day, Used various hammers from the back...
-- started with a rubber mallet, went to ball peen hammer with wood block, then went to small sledge with wood block, rotating disc as I tried to "persuade" the rotor to come off.
Also tried some "persuasion" from the front of the disc, near the lug nuts. (Toyota suggested this.)
No luck. That rust must have welding those things on pretty tight.
Finally, a guy at my local Autozone suggested using a torch to heat up the rotor, near the hub/lug nut area and continue to use the (large) hammer from the back, rotating a quarter turn every so often. I tried that, but it still didn't pop off.
My question regarding the torch method, how long should I keep that propane torch on there? I tried about 20-30 seconds, then tried the hammer. Was that too short? I know rotors can take a lot of heat, but I was concerned about the hub bearings. Should I just try again, but keep the heat on longer? I'd really like to get my Brembo rotors on (which have the 2 extra holes to help when getting them off the hub someday.)
1998 Camry LE
5SFE
If you're not livin' life on the edge, you're taking up too much space. (stolen)
