Installing kill switch
I bought a kill switch on EBay from KillSwitch.com and intend to install this on my 2004 Camry LE. The instructions state (in part): (1) locate the fuse access cover in the front seat area; (2) locate the 15 amp fuse that prevents the engine from starting, and remove it (3) feed the kill switch wires from behind the fuse panel to the front side of the fuse panel and insert the two ends into the fuse space [there is a 15 amp fuse on one of the kill switch wires] (4) mount the switch. Does this sound okay to you?? I'm strictly an amatuer at wiring and I don't want to blow the electronics! Also, and clever suggestions on where to mount the kill switch? Thanks- Richard
