Wrong Enegine Sent - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2006, 04:50 PM   #1 (permalink)
View mike7869's Photo Gallery
Wrong Enegine Sent
A while back i ordered a NONE CALI 5SFE, and when i got it i thought i got what i ordered, but it turns out that i have a CALI engine. I am sure all of you know the difference between the two. so i called the place i ordered it from and they keep telling me its a NONE CALI engine, but i can prove that it is. my ? is should i go after then, bc i had to go through a bunch of crap to get this thing to run right. or should i just say screw it. they are in a differ state tho.
mike7869 is offline   Reply With Quote
Old 05-04-2006, 05:00 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Use your original intake manifold and it shouldn't make any difference. We always use the original intake on an engine swap as that eliminates ECU issues.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 05-04-2006, 05:02 PM   #3 (permalink)
the intake is not the only problem, there are snesores in the back of the engine that i have not conectors for, the injectors where bad, and i could not use my new ones, and i don't even have my old intake. they just keep telling me that i am wrong, and that i have no idea what i am talking about, and they say they had a dealer that can back them up. LIES LIES LIES
Old 05-04-2006, 05:38 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
The sensor on the back is a knock sensor and some NADM cars don't use it, that is correct. However you don't need to make sensors happy, you need to make the ECU happy. What happened to the original intake manifold that came with the car?
雄のハヤブサ
Old 05-04-2006, 05:44 PM   #5 (permalink)
the old intake is gone, the engine came with one. so i thoght y keep it. so u think i should not make a big deal about this
Old 05-04-2006, 05:55 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
I'd just go to a salvage yard in your area and get the intake/sensors from a car just like yours. You may get lucky and everything work out ok. I swapped a Corolla engine for a guy from NY while he was here on vacation and had to grab two sensors from the head to make the check engine light happy. The NY sensors were quite a bit different than the GA sensors though both cars were same model and trim.
雄のハヤブサ
Old 05-04-2006, 06:10 PM   #7 (permalink)
y would the NY be any different, i thought only cali cars a differ..
Actualy CAI on ebay 92-96 4cyl? Or just wrong wrong wrong RedPhoenix 3rd & 4th Generation (1992–1996 & 1997–2001) 19 07-14-2005 03:56 PM
Wrong Transmission Fluid?? dilmurat 2nd Generation (2005+) 5 04-03-2005 10:44 AM
WTF is wrong with americian girls Aaagogo Off Topic 29 02-24-2005 11:58 PM
whats wrong with this mix? alex Off Topic 12 02-01-2005 12:13 AM
Salvage yard sent me the wrong engine!!!What would you do? bennington28 General Discussion 4 08-08-2003 01:59 AM
