hitting the dyno in 6 hours - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2006, 01:23 PM   #1 (permalink)
The Other White Meat
terrastrife's Avatar
cant wait!
ill be happy with anything over 85fwkw in the cars current running condition.
ill see if i can film it, youll get to see my home depot air intake, lol. complete with house insulation and zip ties ^^
so that means about 9 hours and ill bring a dyno sheet home =)
terrastrife is offline   Reply With Quote
Old 05-05-2006, 01:27 PM   #2 (permalink)
View TRDGen5.5camry's Photo Gallery
sound good man
TRDGen5.5camry is offline   Reply With Quote
Old 05-05-2006, 03:12 PM   #3 (permalink)
Camry Under Construction
05Cam-Weasel's Avatar
View 05Cam-Weasel's Photo Gallery
exactly how many hp is kw? so 85 fwkw is how many fwhp?
Weasel(n.)- A naive user, one who deliberately or accidentally does things that are stupid or ill-advised.
05Cam-Weasel is offline   Reply With Quote
Old 05-05-2006, 03:21 PM   #4 (permalink)
seeming thats a stupid question, type this into google (without the ")
"85 kw in hp"
you can do the hard work.
wait... that was hard?
Old 05-05-2006, 05:38 PM   #5 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
113.94 HP = 85 kw? is that right?
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is online now   Reply With Quote
Old 05-05-2006, 06:12 PM   #6 (permalink)
View leasaunce's Photo Gallery
GO TERRA!! bring back the result ay
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 05-06-2006, 10:13 AM   #7 (permalink)
ok i somehow misplaced my dyno sheet, ill look for it again in the morning..
92.6kw on a cold engine if i had warmed it up it woulve maybe been 1-1.5kw higher, as the 2nd run right after the first one pulled higher... BUT
there was a massive dip in the curve at ~5000rpm where the power peak wouldve been.
torque curve nice and flat from 3000-5500rpm
did it with my 18's which are 2x heavier then the stock 15's.
i still need to replace plugs and leads which are 150000km overdue among other general service things.
pulled 0.1kw more then a 3sge 5spf MR2 =)
Old 05-06-2006, 10:54 AM   #8 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
do you have any major mods to constitute a dyno?
WhiteRabbit is offline   Reply With Quote
Old 05-06-2006, 12:24 PM   #9 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
so that's only 127hp or so??? wow...that's brutal....even when I hit up the dyno and there was something wrong, I still came out with much better numbers.....
what was your torque? or do they only give one kw curve on the aussie dynos?
HaHa
Old 05-06-2006, 12:49 PM   #10 (permalink)
how many hp are you putting out eye8pussies?
Old 05-06-2006, 01:14 PM   #11 (permalink)
TN Pussy Man
if I remember correctly - around 150hp and 170ft/lb, but peaking at abour 3-3.5K....there was something wrong with either the knock sensors or the egr at the time, as it seems that the acis didn't kick in and the car was going into open loop and bogging down continuously
there was only one small peak in the graph at around 3.5, and then it was about flat to downwards from there instead of the second higher peak at 4.5-5K that is supposed to occur in both the 1mz and the 3vz - the car would have been perfect for autocross
this was dynoed with a stock intake w/ k&n filter and a custom y-pipe but with a restrictive catback due to some really bad axle-back piping at the time and 17s
the knock sensors don't seem to act up anymore since I switched my plugs and my egr seems to be fine now that I've given some good cleaning, and I've fixed and added more, so I'd like to hit up the dyno sometime and hopefully get a proper dyno
HaHa
Old 05-06-2006, 08:33 PM   #12 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Wow! Thats interesting. I put down 92fwkw (130hp) on my stock 2VZFE with a stuffed auto trans. Which is about right considering the 2VZ is factory rated at 157hp.
What do you think the problem could be?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-06-2006, 11:02 PM   #13 (permalink)
no idea what the problem is, but heres a start (and I HAVE NFI HOW I LOST MY SHEET)
btw remember i pilled higher then a 3SGE 5spd MR2 for a comparo, it was a Dyno Dynamics 2WD roller in shootout mode so everyones results were in line.
i have about 255,000km on the car
the plugs have been changed once, at ~100,000
the fuel filter, pump, leads, cap, rotor, all sensors have never been changed.
TWO of my injectors are wired with speaker wire.
running 10w30, i seem to be loosing oil somewhere/at hte sme time i have possibly less pressure. running dino 10w40 i would have oil seepage out of the oil cap and valve covers but not enough to warrant a top up of oil (it wasnt even noticible on the dip stick) but now with the synth 10w-30 its almost due for another oil change (within the time of this tank of petrol) ive had to use the remaining 1L in the 5L bottle to top up, although there is no seepage from the oil cap or valve covers
oh WHERE to start...
Daniel
R32 GTR
193.1
Darren
180SX
160.0
Chris
VN V8
159.4
Adrian
RX7 S4
156.7
Andrew
RX7 S4
149.4
Josh
180SX
147.5
Steven
180SX
139.4
Andrew
200SX
139.1
Robert
Cordia
135.6
Chrs
S15
134.5
Ryan
Supra
129.3
Ian
RX7 S2
129.3
Gilbert
VS V6
125.7
Paul
RX7 S2
101.5
MEE HERE =)
Camry
92.6
Jess
MR2
92.5
Shane
Jeep
91.9
Tristan
260Z
76.4
Adam
MX5
64.3
Tim
RX7
61.2
Matt
Gemini
58.2
Old 05-07-2006, 11:39 AM   #14 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
so you have injectors wired with speaker wire, a home depot intake, and huge 18s that weigh twice as much as the stock rims- and you lost the dyno sheet...
why did you want to dyno again? just for the heck of it orrr?
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 05-07-2006, 11:51 AM   #15 (permalink)
just for the heck of it, it was only ~25USD and it came with a BBQ and Drinks =)
Dyno Days scandelous General Discussion 1 05-03-2006 08:14 AM
Dyno Power Services stood me up!!! I'm FUCKING PISSED OFF!! speedemn Feedback: Buyers, Sellers, and Vendors 9 10-03-2004 07:08 PM
Hyde hit the dyno JekylandHyde MR2 Forum 3 09-07-2003 10:53 PM
2002 Corolla five-speed Dyno results before/after cai Chris Corolla S Archived Corolla threads 22 09-27-2002 02:12 PM
I Out-Dynoed A Dyno! ericlee303 Hardcore Tech and Competition 24 04-12-2002 01:36 PM
