20w-50 seems to thick to me, 10w-40 is the thickest I would ever go considering 5w-30 is specified. The fact that you are using a 50 weight at a hot idle and only seeing 18 psi is not good, the resistance to flow alone should have it higher. Oil pump seems like a good possibility. Why are you using a 50 weight? Is there an oil consumption problem or...? 50 weight would seem like it would cause oil starvation problems? Worn out bearings with large clearances could also reduce oil pressure. I didn't think an oil pump would go that quickly, I would think it would be a gradual thing as clearances in the oil pump rotors increased? I'm also assuming that there is no oil leakage from the pump through the new seal. If you just replaced the pump rotors(inner and outer) if the clearances are over spec, wouldn't this fix the pump pressure problem? I think that the only time you replace the pump body is if the outer rotor to pump body clearance is over spec. But then again, what the hell do I know...
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
