Bumpy Clutch pedal travel. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2006, 12:40 PM   #1 (permalink)
View blueapple's Photo Gallery
3rd Generation Bumpy Clutch pedal travel.
Ever since I had the clutch replaced, it's been there somewhat, Geting a littl better though, but still there and it's annoying.
Pressing and releasing clutch pedal feel "bumpy" as in not smooth, like the pedal chases my foot while tripping over things... I get this feel when the engine's reving anywhere above 1k rpm, the higher the rougher.
If I just hold the pedal there (anywhere along the stroke ), it's fine, no vibration.
Once in a while, problem disappears, or so much better that I don't notice.
I'm thinking one of the cylinders.
when I'm sitting in the car with the engine off and everything's obsolutely quiet, I can hear a small whining noise when I first press on the pedal, so small that I can't hear anything if it's parked on a street with traffic.
So if it's the cylinder, which cylinder could it be? Considering it's RPM related and only came up after the clutch change, I'm thinking the slave cylinder. ( you know how the push rod kinda goes into the piston as clutch wears, so now it's out again, and it's rubbing against rusted surface ). But the whinning noise seems to be coming from insdie the car, totally not related?
Everything else is normal, no throw out bearing noise.. not chattering, and also, when the clutch is smooth, the engine sounds much better too.
blueapple is offline   Reply With Quote
Old 05-06-2006, 03:35 PM   #2 (permalink)
View marc780's Photo Gallery
The whining noise sounds like it would most likely be fluid pressure escaping from the hyraulic clutch system. But if this were so, youd think you would notice a fluid leak.
Crawl under the car, have someone work the clutch while you listen for this noise. If you can find a rebuild kit for these cylinders i would just rebuild them both. If not, replace.
If you are really really on a tight budget, remove the cylinders, take them apart and clean them. And "hone" the inside of the cylinders by going round and round (not back and forth!) with fine steel wool for a minute. Followed by a thorough cleaning with brake fluid and compressed air and reassemble using old parts if they are good (if you must).
Help!!! Clutch pedal doesn't do anything!! aaron7 Archived Corolla threads 3 04-03-2006 07:19 PM
Clutch Pedal vibration after clutch change 96 Camry blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-08-2006 12:54 AM
Cramped around the clutch pedal Sonny 2nd Generation (2005+) 16 06-07-2005 05:05 PM
1990 4Runner Clutch Pedal BROKE wilco333 4Runner Lounge 2 02-13-2005 05:36 PM
Squeeky Clutch pedal. Chris Corolla S Hardcore Tech and Competition 7 07-20-2004 11:45 AM
