lowering springs...not low enough. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2006, 04:36 PM   #1 (permalink)
View MattSWE's Photo Gallery
2nd Generation lowering springs...not low enough.
After I installed my intrax springs for my 91 DX, the front lowered decently but the rear is still jacked up. I know I have 4 banger springs but im not happy with the height. How else can I lower my camry, air shocks? I just want the car to be low and not so damn high up in the air. I have 205 40 17 rims and tires btw.
MattSWE is offline   Reply With Quote
Old 05-07-2006, 02:06 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307675
The Intrax springs are known to do that. Either get a nice big sub for the back (this evens it out) or try cutting one coil of the bottom of the spring.
-Charlie
Old 05-07-2006, 06:12 PM   #3 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
I know how you feel man. With Dropzones on gen 3's it's reversed, it's higher in the front...sux. Coilovers are your only safe option.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 05-07-2006, 06:17 PM   #4 (permalink)
Broken Toy Hoarder
View hirosada's Photo Gallery
I'll probably be snipping a coil front and back on my wagon. It too has Intrax springs. But, being a wagon with a sub setup there's more than enough weight to even it out. Keep in mind however, if you do cut a coil and you have passengers in the back, the car will almost look comical. Ever see a stock sedan with blown shocks, fully loaded with people? Hah, you get my drift.
hirosada is offline   Reply With Quote
Old 05-07-2006, 06:38 PM   #5 (permalink)
View .tony. .riot.'s Photo Gallery
Ksport will give you an uneven drop too. The front is higher than the rear.
.tony. .riot. is offline   Reply With Quote
Old 05-07-2006, 07:19 PM   #6 (permalink)
View 2000LEV6's Photo Gallery
how about sprint spring on gen 4, i have it but worry to install cause i heard the drop is uneven between front and rear.is that correct? should i just do it or find diffrerent spring.
sorry to jack the tread but i need opinion on this.
VroomCamryV6
2000LEV6 is offline   Reply With Quote
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Thinking about selling my lowering springs... celicaduck General Discussion 0 05-30-2005 12:35 PM
Question for the people with lowering springs.. strmagiceet Camry & Solara Lounge 18 04-14-2005 06:25 PM
