Camry acting strange. Help. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2006, 05:51 PM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
This is the second time this has happened to me now. I'm driving regularly and the car shuts down as I'm slowing down or at a stop...First time (a few months ago) I had my music up, but the amp was only a 200W RMS one or so, and the engine cut as I was turning and I hit a curb. Second time, about a few days ago, I had the music up, but this time with a 1000W RMS amp, and my engine cuts at the red light.
A couple days after that, I'm driving, and as I slow down and enter a parking lot, my engine hesitates, the rpms drop from 1000 to about 300, then back up again, wanting to die. I shut it off, start it back up, and its fine.
So I just want to know what could be causing this. My guess is that my alternator is being stressed by my sound system. Thoughts? Thanks.
WhiteRabbit is offline   Reply With Quote
Old 05-09-2006, 07:24 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
I would ask the Audio gurus here about a capacitor to keep the alternator from being bogged down so much. A huge load on the alternator will slow your RPMs. As you know if your RPMs drop too low the car will stall.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 05-09-2006, 08:17 PM   #3 (permalink)
View 92phantom's Photo Gallery
i agree check out about a capaciter. helps tremendously.
92phantom is offline   Reply With Quote
Old 05-09-2006, 08:36 PM   #4 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
It could be a short. When i had a short it killed my car 5 times including all the power accesories but the were kind of flasing.
V6LE_CAMRY is offline   Reply With Quote
Old 05-09-2006, 10:59 PM   #5 (permalink)
TN's furry friend
^where was your short?
Old 05-09-2006, 11:23 PM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
definitely do NOT look into a capacitor. a cap will actually put MORE strain onto your system. u said you have a 1000wRMS amp... what brand and model is that? and have you upgraded your alternator? if not, i can almost guarantee it is the alternator that is going and will be gone very shortly!
MrSo0h0o is offline   Reply With Quote
Old 05-10-2006, 12:52 AM   #7 (permalink)
V6LE_CAMRY's Avatar
Positive battery connection. The lower part of the alunimum section was hitting a ground piece of the crise contol module (din't have a cruise cover back then)
Old 05-10-2006, 04:24 PM   #8 (permalink)
Camry97
View ichlove's Photo Gallery
Do you still have the same problems without the audio system because it might be something else causing the problems unless you are sure its the amplifier.
ichlove is offline   Reply With Quote
Old 05-10-2006, 10:56 PM   #9 (permalink)
View marc780's Photo Gallery
Put the charging system on a tester, maybe you need a greater capacity alternator? Id turn on the stereo and put a VOM on it at least. At idle, A VOM applied to the battery should read no less than 13.9 volts. But thats just a cursory check, although you may have already answered your own question.
Old 05-10-2006, 11:20 PM   #10 (permalink)
Sorry bro but you are misinforming people about capacitors. Capacitors have no draw on the alternator therefor they cannot put more strain on the system. Think of a capacitor as a battery which fills up when energy is available and discharges when the energy is low keeping the alternator from bogging down so much. I know this because it is my job.
Old 05-11-2006, 01:14 AM   #11 (permalink)
TN's furry friend
yea, i have a voltmeter built into my inline fuse and the voltage seems fine at idle. it does drop slightly whenever the bass hits though, how much it drops while im driving i dont know
Old 05-11-2006, 09:00 AM   #12 (permalink)
TN's furry friend
hrmm, it did it again today. constantly wanting to die (it did too) at a stop or when slowing down. my sound system wasnt on this time...
Old 05-11-2006, 12:04 PM   #13 (permalink)
Gameroom cash: $304355
A weak alternator or a slipping alternator belt can cause the symptoms you describe, but there are other things that can cause it.
Try cleaning the idle air control valve inside the throttle body. Do a search for "idle air control valve". A dirty idle air control valve can also cause the symptoms you describe.
Another thing that can cause what you describe is water in the fuel. Try a couple of cans of gas line antifreeeze or gas dryer and run the current tank down as low as you dare and then get fuel at another station than the one you used for the current fill-up.
Mike
Old 05-11-2006, 04:39 PM   #14 (permalink)
TN's furry friend
ill check my belts later today, thx
Old 05-11-2006, 09:06 PM   #15 (permalink)
TN's furry friend
alt belt seemed fine.
but does a loose timing belt seem plausible? I haven't done the recommended 60k interval change yet.
Strange Stalling Problem on 93 Camry 4cyl - Please Advise MSgtVac 3rd & 4th Generation (1992–1996 & 1997–2001) 35 11-02-2008 01:26 PM
My camry is acting crazy. help? trdboy15 Camry & Solara Lounge 8 04-11-2004 09:10 PM
AE86 acting strange baartman Archived Corolla threads 7 05-21-2003 11:23 AM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
