How the heck do you REassemble struts/springs (autozone spring compressors) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2006, 09:34 PM   #1 (permalink)
View greeneclipse's Photo Gallery
4th Generation How the heck do you REassemble struts/springs (autozone spring compressors)
I rented the autozone spring compressors for my strut install, but I can't get the damn springs compressed enough to put the uppear seat, mount, and nut back on.
I'm using new kyb br-2 shocks and the stock coil springs.
Seems like the autozone compressors aren't long enough...is there a trick to the placement of these things ?
thanks all
greeneclipse is offline   Reply With Quote
Old 05-09-2006, 11:03 PM   #2 (permalink)
I actually toyed with that idea, but then I thought it has to be possible with just one set.
looks like I'll have to pick up the other set if they have one. Did you use 4 compressors on the same spring, or did you use 3?
Old 05-09-2006, 11:07 PM   #3 (permalink)
Black since 1985
View Ruffrydasean's Photo Gallery
Whatdo they look like.. I used them.. I had one where it's 2 hooks with a long rod and a bolt(A pair of this assembly..) Hook both on either side and tighten up...(4 way lug wrench thingy made it go quick)
Take a pic... maybe I (or we) can help you
Lexus officially announced that they arent f***ing around anymore
"We aint f***in' around anymore." - Lexus Employee
Ruffrydasean is offline   Reply With Quote
Old 05-10-2006, 02:08 AM   #4 (permalink)
That sounds like the same pair I have....Did you use them on the stock springs? I've heard people have no problems using lowering springs due to their shorter length, but the OEM springs are a bitch.
heres a pic of them from the autozone website:
http://autozone.com/servlet/UiBroker...EGRN%7C%7Etrue
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 03:02 PM
