Indiglo gauges - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2003, 05:04 PM   #1 (permalink)
View JohnQ's Photo Gallery
Indiglo gauges
I got my indiglo gauges installed today and works great for like 3 hours. After getting for work when I turned my headlights on ,the speedometer indiglo does'nt work but the rest are working.I tried to switched the connectors but no luck.Anyone have this problem before?HELLP!
JohnQ is offline   Reply With Quote
Old 02-19-2003, 09:37 PM   #2 (permalink)
rayray's Avatar
View rayray's Photo Gallery
sucks...
you switched the connectors and it still doesn't work? you may want to see if there's any pinched wires coming out of that gauge. also check the pins inside the connector to see if they're not bent or broken. other than that i'm not sure what else it could be. good luck.
-rayray
rayray is offline   Reply With Quote
Old 02-20-2003, 12:45 AM   #3 (permalink)
The terrorist
View Xenon's Photo Gallery
Check your grounds, ground is usually the biggest electrical problem!
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 02-20-2003, 04:06 AM   #4 (permalink)
rayray's Avatar
i was thinking that it could be the ground as well... but that would usually affect all the faces... not just the speedometer one. if it's just the one face... and you've tried connecting it to other leads that work on the other faces... then it's probably something isolated to the speedometer face (wire, connector, etc.)
-rayray
Old 02-20-2003, 01:42 PM   #5 (permalink)
Yup, I checked everything ..tried to switching the ground,power source ,connectors ..but no luck at all.There goes my 40bucks .
Anyways , I just ordered another 1 from ebay..35+ shipping.
Thx guys, appreciate your time.
Old 02-20-2003, 02:27 PM   #6 (permalink)
View tinman831's Photo Gallery
where did you buy them from? cant you return theM?
tinman831 is offline   Reply With Quote
Old 02-22-2003, 01:59 PM   #7 (permalink)
View Vampress's Photo Gallery
I have a electro luminous white face indiglow gauges frommy friend for Gen3. The problem is i know where all the wires go but except one. The one connect to the "ground" wire of the car. I don;t know what is the color of the ground wire? I have a 94 camry le. Can anyone tell me which one is it?
Vampress is offline   Reply With Quote
Old 02-23-2003, 09:33 PM   #8 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Here's a guide I wrote last year on how to "fix" a gauge if it breaks...not sure if it's the same problem, but no harm in testing it out.
http://www.toyotanation.com/showthre...hlight=indiglo
Silver Streak is offline   Reply With Quote
