I'm a little confused about auto headlamps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2006, 11:30 PM   #1 (permalink)
Frugle's Avatar
View Frugle's Photo Gallery
Gen5 I'm a little confused about auto headlamps
So I bought my 03 used, when I got it, I realized that if I had the headlamps on, and then opened the door, I didn't get a beep like most cars do warning me the lights were still on.
So I figured the old guy that drove it before me used one of the "press the pedal 16 times, open and close your door 45 times, and start the car 3 times before pressing the roll window down button 54 times." and turned it off...
but by accident, I left my lights on the other day when I parked in the street so I could pull the other car out of the driveway (to make room) and when I walked back up, my lamps were off... front and back, and nothing inside... but if I turned the thing to off (or DRL) and then back on, the lights turned back on..
so I tested again, after pulling the car in, I left my lights on, and a couple minutes later they turned off..
so does this mean at night, if I park, can I leave my lights on and they auto-shutoff, and when I turn the car back on they turn back on?
does this run the battery dead?
do all camrys do that?
I know they don't automatically turn on, but do they automatically turn off?
Frugle is offline   Reply With Quote
Old 05-10-2006, 11:35 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
^Auto-shutoff only works if you lock your doors. If you leave your doors unlocked, your lights will stay on. And none of the Camry's beep to tell you that you left your lights on.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 05-11-2006, 12:08 AM   #3 (permalink)
Resident slacker
kgasso's Avatar
View kgasso's Photo Gallery
Killed my battery once because I armed the alarm before my passenger shut their door, so the doors locked/unlocked/relocked.
Since then I make it a point to turn them off manually.
Still wish I could make the car scream if I don't.
kgasso is offline   Reply With Quote
Old 05-11-2006, 12:19 AM   #4 (permalink)
2005 Camry XLE V6
View 05CamryGuy's Photo Gallery
mine turns off 30 seconds after all doors/trunk are closed regardless if they are locked. I park mine in the garage, never need to lock the doors and never turn off my lights manually. I've not had any problems with it yet.
You can also try this... close your doors (all of them). Press Lock once to lock the doors, and within 30 seconds, press Lock again - the lights should all turn off after the 2nd press.
2012 Lexus RX350 Luxury Pkg w/Nav + HUD, ML & PA
2010 Lexus IS250 AWD w/Nav
2007 Lexus ES350 Ultra Luxury w/Nav, ML & PA
2007 Camry XLE V6
2005 Camry XLE V6
05CamryGuy is offline   Reply With Quote
Old 05-11-2006, 12:28 AM   #5 (permalink)
Frugle's Avatar
hey, looks like you have the exact same car as I do... is it the same color (your sigs a little dark..) got any other pics? I wants some ideas as to what to do with mine
Old 05-11-2006, 12:37 AM   #6 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Yep Mine does that too, even if I open the door before I remove the key. If I remove the key then open the door, I can use the keyfob to lock it twice and turn off the lights.
drunken_panda is offline   Reply With Quote
Old 05-11-2006, 01:03 AM   #7 (permalink)
View Camry005man's Photo Gallery
My Camry, if I lock door manually and get out of it then press remote, it will turn off lights. If I get out of my baby without locking doors, then press remote, first press will lock doors and second press will turn off lights. If leave the lights on, will turn off by itself within 30 sec.
Camry005man is offline   Reply With Quote
Old 05-11-2006, 04:59 AM   #8 (permalink)
toot toot ahhhh beep beep
View cuttooth's Photo Gallery
oh..i didnt know this about the headlights shutting off automatically
'02 is300, eShift, LSD
'94 toy pickup, 22re, 5spd, xtra cab
cuttooth is offline   Reply With Quote
Old 05-11-2006, 06:39 AM   #9 (permalink)
View caveman017's Photo Gallery
Once you open the door in mine, they turn off no matter what position its in
1997 Camry LE, i-4, auto, KYB GR-2 and mounts in the front
caveman017 is offline   Reply With Quote
Old 05-11-2006, 07:17 AM   #10 (permalink)
View 02whiteLE's Photo Gallery
Yep, mine too. I"ve had people tell me when I get out of the car, "Hey, you left your lights on." (I usually only click the remote once, because I know they shut off after 30 seconds)
'94 Camry LE. IDK, that minty green color that looks silver in a pic, until you see the car, and it's actually green.
02whiteLE is offline   Reply With Quote
Old 05-11-2006, 08:55 AM   #11 (permalink)
Banned
LunarMist's Avatar
View LunarMist's Photo Gallery
Seeing as how this has been discussed before, try a simple search the next time.
But as already stated, in 2002-2007 Camry's, if you look at any brochure or any website that gives specifications on the car, it will say "Halogen Multi-Reflector Headlamps with Auto-Off". 2005-2007 Camry's will add "Auto-On/Off". That means that there is a timer-delay on the lights (mostly designed for people with driveways that lead up to the front door to light up the area for safety and security) that will automactically shut off the lights after 30 seconds. It is not harmful to the battery if you do this daily, it is mentioned in your owners manual. The only time you dont want to do this is if you are going away for an extended period of time. Then you should make sure you manually turn the light switch to "DRL" or "DRL Off" (or "Auto" for people with 2005-2007 Camry's). 1997-2001 Camry's do not have the time-delayed auto-off feature. They have a simple auto-off feature where if the door is opened with the ignition off, the lights will turn off immediately. 2005-2007 Camry's have an "Auto-On" feature as well so if you get home at night your low-beans will be on and shut off automactically. But in the morning when you turn the car on, the DRLs will come on if you have the lights set to "Auto" and the low-beams will be off.
Hope everyone has been helpful.
LunarMist is offline   Reply With Quote
Old 05-11-2006, 08:59 AM   #12 (permalink)
Alloy's Avatar
View Alloy's Photo Gallery
exactly what happens on my 04 SE too. I think is a great feature. People said I forgot to turn off the light, but I think the 30s delay is designed for people walking from garage into their home. It's a Camry, it deserves such automatic function.
:creature:07 Magnetic Grey Metallic SE
Alloy is offline   Reply With Quote
Old 05-11-2006, 05:44 PM   #13 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
you can also turn them off by hitting the lock button twice on the remote.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 05-11-2006, 10:16 PM   #14 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $590957
View xpeed's Photo Gallery
My headlights turn off automatically while I have my doors opened or unlocked. It stays on for thirty seconds and turns off. Alarm on or off. If you press the alarm twice, it turns off. My dad's Gen 5 turns off by itself when the alarm is on. But my Gen 5.5 doesn't need to be.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 05-11-2006, 10:50 PM   #15 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
for gen 3 and 4, i think if you remove your key and then open the driver's door, the main lights / headlights goes off.
I rented a Sienna 2006 y'day and it does not have that feature..
skewe is offline   Reply With Quote
Got Trick by BC Auto. Speed300 General Lexus Discussion 7 06-19-2006 02:30 PM
Manual vs auto question Bakemono 2nd Generation (2005+) 7 03-28-2005 12:46 AM
5 speed auto or 5 speed stick Talisman Camry & Solara Lounge 22 12-17-2003 03:17 PM
