Gauge Install Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2006, 09:11 AM   #1 (permalink)
View thisisntjoew's Photo Gallery
3rd Generation Gauge Install Question
I am wondering if I can tap into the wires from the sending units for my o2, water temp, and oil pressure to use when setting up my own gauges. Does anyone know if this causes problems? Do all gauges use the same power signal from sending units, or are they all different?
THANKS!
thisisntjoew is offline   Reply With Quote
Old 05-11-2006, 09:27 AM   #2 (permalink)
View noodlerooney's Photo Gallery
You have to use the sensors that are made for the guages that you are using. Otherwise, it would be to easy.
00 Solara SLE V6 1MZ-FE, 16.5K miles "Garage Queen"
94 Camry LE I4 5S-FE
noodlerooney is offline   Reply With Quote
Old 05-11-2006, 10:52 AM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
a/f guage you can tap the 02 sensor.... oil pressure you have to hookup a new sensor because the stock one only reads if it's under 4psi or something to turn on the oil light..dunno about water temp
Old 05-11-2006, 11:52 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If the gauge for water temp is electronic, it'll come with a sender.
You need to drill and tap a hole for this sender. I'd drill and tap into the water neck the upper radiator hose connects to.
The sender looks something like this:
http://autometer.com/cat_accessoriesdetail.aspx?vid=36
"Skoolin' the unlearned!"
Old 11-17-2011, 08:44 AM   #5 (permalink)
So for anyones future reference... I had to replace original the oil pres. sending unit with the one that came with the gauge and I needed to buy thread adapters for it to fit.
For the water Temp sensor, I spliced into the existing unit HOWEVER the signal travels through the "path of least resistance" and so you cannot display the water temp on the stock gauge as well as the aftermarket by using 1 sending unit.
3rd Gen/5s-fe/Camry
Can I install the new Instrument Gauge Cluster (OPTITRON) in my 2002 XLE V6? Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 1 02-09-2005 04:31 PM
AE86 Hatch rear strut bar install question ?!?! Red_85_AE86 Archived Corolla threads 2 08-29-2004 05:35 PM
Quick question about stereo install Fuzion Audio, Video, and Security - Tech 7 08-10-2004 10:39 PM
Gen. 2 V6 gauge cluster question xavior66 Camry & Solara Lounge 10 08-09-2003 05:38 PM
