I know I'm going to take abuse for asking... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2006, 02:56 PM   #1 (permalink)
Aspiring to mod...
GrayGen4's Avatar
View GrayGen4's Photo Gallery
4th Generation I know I'm going to take abuse for asking...
I know I'll probably get a beating for this one, but I didn't find anything from the search. I know Gen 4 is 99-01. What is the difference between Gen 4 and 4.5?
GrayGen4 is offline   Reply With Quote
Old 05-11-2006, 03:14 PM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
gen 4 as broad term covers 97-01.
Specifically,
gen 4.0 is 97-99
gen 4.5 is 00-01
What's actually different on the cars?
gen4.5 has better headlights, taillights. More standard equipment like a CD player, larger standard tires/wheels combos on most trims, etc...
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 05-11-2006, 03:20 PM   #3 (permalink)
Aspiring to mod...
GrayGen4's Avatar
4th Generation
Excellent, thanks for the info...and lack of general mistreatment.
Old 05-11-2006, 07:22 PM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Specifically,
gen 4.0 is 97-99
gen 4.5 is 00-01
how can you say better head and tail lights???
i think the 97 to 99 is a hell of a lot cleaner with the rear tails, and the only reason gen 4s are switching to 4.5 heads is to get the clear lens or the halo lights
all those things can come with any model also
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 05-12-2006, 01:40 AM   #5 (permalink)
Home of the Demon Cam
CamryOwner98's Avatar
View CamryOwner98's Photo Gallery
So true, if the gen 4s had clear headlights, I'd be perfection. I like the rear of my gen 4 more than the 4.5
Mods:
HID TL Bi-Xenon Projectors~Auxillary Bosch Mini Projectors~
Superflux LED Tails~
Euro guages~Halogen Fogs~
CamryOwner98 is offline   Reply With Quote
Old 05-12-2006, 01:53 AM   #6 (permalink)
The Greatest
View CamNub's Photo Gallery
The taillights are kind of jagged instead of straight for the 4.5.
CamNub is offline   Reply With Quote
Old 05-12-2006, 02:57 AM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
the 4.5 rears are much easier to see if youre behind one.
terrastrife is offline   Reply With Quote
Old 05-12-2006, 03:00 AM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Specifically,
gen 4.0 is 97-99
gen 4.5 is 00-01
I think the word your looking for there is "different"...
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-12-2006, 03:24 AM   #9 (permalink)
View AmanO's Photo Gallery
I would rather have a 4 bulb setup than 2 if I have DRLs or auto headlights and retroing HID is a lot easier.
The tail of a 4.5 uses fewer bulbs, looks better (clearer housings nicer lines brighter reverse light (i think)
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
Old 05-12-2006, 08:10 AM   #10 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Styling differences are what's visible.
Differences are in the body improvements are mainly NVH, but that is an ongoing improvement (eg the 98 has quieter windscreen than the 97)
The 97 & 98 body had an external whip antenna for the base (CE) model, 99 and on, antenna is masked on the rear window, reducing the different parts count in production.
Weld points are updated so body welds are reduced for areas that do not need the better strength, rigidity and production speed. More asphalt sound deadening.
Inside differences, the gen4.5 has revised HVAC system that incorporates a pollen filter, if you want to put one in. Different layout of control module placements, I believe the 01 had LATCH points for car seats.
01 If I recall, had the VVTi engine for V6... but I am not 100% sure and also has a muffler with a spring loaded gate to allow higher through put of exhaust gasses by reducing back pressure at high engine rpms.
As you can see these changes are done little by little and carries over the next gen as well.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-12-2006, 11:23 AM   #11 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Everyone is entitled to their opinions. Personally, when the Gen 4's came out I told the dealer I wouldn't buy a new Camry until they widened the tail lights. I have an '01 but I wish it was wide all the way across.
Dave's is offline   Reply With Quote
Old 05-12-2006, 11:32 AM   #12 (permalink)
View trickyazn's Photo Gallery
no vvti for ANYTHING 4gen or 4.5 gen.
trickyazn is offline   Reply With Quote
Old 05-12-2006, 02:35 PM   #13 (permalink)
Is the pollen filter the same as a CAF?
Old 05-12-2006, 02:51 PM   #14 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
IMO, the best gen4 combo is the tails from 99-00 and those clear headlights from japan for the same model years (garcia's). Gen4.5 illuminte better cus of their clear headlights.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-12-2006, 03:19 PM   #15 (permalink)
Official TN OT Hater
Waghle's Avatar
View Waghle's Photo Gallery
i think the gen 4.5 heads and tails BOTH look worse than the 4..
but they are brighter.
Waghle is offline   Reply With Quote
How much ABUSE can an echo handle. its an echo Yaris, Vitz and Echo Forum 20 07-30-2008 11:48 AM
Abuse a Mini (GTA only) Phi Canada 65 06-24-2003 10:49 PM
O/T Dealer Abuse dj14901 General Discussion 8 09-29-2002 11:13 PM
