Distributor Swap! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2006, 09:34 AM   #1 (permalink)
View profitwho007's Photo Gallery
3rd Generation Distributor Swap!
?Hay everyone I'm new here and I would like to know how to swap to a stand alone ignition system like msd or crane? I have a 1995 "Federal" 5sfe, where the coil is in the DISTRIBUTOR! Will the 96 bolt pattern line up and if so what kind of wiring nightmares will I encounter?
profitwho007 is offline   Reply With Quote
Old 05-12-2006, 10:28 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Read these 2 threads:
http://www.toyotanation.com/forum/t22512.html
http://www.toyotanation.com/forum/t52147.html
You don't need to swap distributors. You can use the internal coil or disable it and use a external coil.
I had a MSD 6A on my 3S-FE. The distributor has a internal coil, but I disabled it and used a MSD Blaster SS coil.
"Skoolin' the unlearned!"
