Originally Posted by toyotabob
It is likely that a seal has been damaged while replacing the drivers side drive shaft (leaks from the transaxle side of the drive shaft)? If so, what measures must be taken to replace?
Theres a seal on each side of the tranny (actually the differential), where the axles go in.
Its possible that one or both of these seals are damaged and/or leaking. You'll have to look at it and find out.
The seals are a few bucks a piece from Toyota. But replacing them is a pain in the ass, as the axle(s) have to be removed. After that, you remove the seal and replace with new one.
