Anybody install a transmission cooler? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2006, 03:33 AM   #1 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
4th Generation Anybody install a transmission cooler?
I was thinking about getting one for my car.
If anybody has installed one, I'd like to know what kind you used and how you installed it. Thanks.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 05-13-2006, 04:02 AM   #2 (permalink)
View yosh's Photo Gallery
I have a B&M Supercooler. I can't remember the exact size. It came in a kit with all the mounting hardware. Did you try searching? I remember there being a thread with pictures. Try solaraguy too.
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 05-13-2006, 11:33 AM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
I have a hayden tranny cooler used for SUVs and big trucks. I just put inline with the stock tranny cooler.
you can see it there. its awesome though.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 05-13-2006, 12:46 PM   #4 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
what about a gen 3.5 camry with the 4 banger engine??
felonyr301 is offline   Reply With Quote
The Following User Says Thank You to felonyr301 For This Useful Post:
Zsrbpk (04-07-2012)
Old 05-13-2006, 12:55 PM   #5 (permalink)
That thing is huge. Aren't you worried about blocking air flow to the radiator?
2000 Camry LE V6
TRD Supercharged
Old 05-15-2006, 12:01 AM   #6 (permalink)
Tom 2000's Avatar
Thanks for the helpful info and pic.
Next question, there's two lines coming out of the transmission.
Obviously one is IN and the other is OUT. Which is which? Thanks
Tom
2003 Corolla Luxel
Old 05-15-2006, 03:59 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Outlet = left
Inlet = right
"Skoolin' the unlearned!"
Old 05-15-2006, 11:23 AM   #8 (permalink)
Aspiring to mod...
GrayGen4's Avatar
View GrayGen4's Photo Gallery
4th Generation
I TOTALLY dig that engine compartment...looks good. Gives me MANY ideas! Kudos!
GrayGen4 is offline   Reply With Quote
Old 05-15-2006, 12:32 PM   #9 (permalink)
Tom 2000's Avatar
Originally Posted by 88 LE
Outlet = left
Inlet = right
Thank you. Now I'll go shopping around.
When you say LEFT, I assume that's LEFT side viewing from the front of the car (towards the engine) and the RIGHT means farther away from the engine.
Thanks,
Tom
2003 Corolla Luxel
Old 05-15-2006, 02:34 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
The outlet is higher up on the transmission (where it comes out of the transmission).
Old 05-15-2006, 03:43 PM   #11 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Outlet is the pipe/tube that attaches to top of trans. you see the fitting. And inlet takes the fluid back to the pan.
You may want to check if the cooler has a thermostat (stacked plate cooler uses the fluid temp vs viscosity) to regulate flow at cold temperatures.
You want a warm transmission, but not too hot to cook the fluid.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-15-2006, 04:22 PM   #12 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
FYI: i've been holding out for hayded 404 model. Thats the model i plan to install on my camry this comming summer. I've researched enough and know this what i want to do, smaller hayden's are good, but since i'm planning to keep the camry for a long time, might as well go BALLER BiG!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-15-2006, 05:43 PM   #13 (permalink)
Tom 2000's Avatar
Thanks again.
What I heard is that I should keep the stock transmission cooler, but plumb the aftermarket cooler AFTER the stock cooler.
If anybody is wondering why I want to install a transmission cooler, I really don't drive the car very hard (on purpose), but I do more and more stop and go driving nowadays and there's a good number of hills to and from work.
Tom
2003 Corolla Luxel
Old 05-16-2006, 11:56 AM   #14 (permalink)
Grenaded piston
88 LE's Avatar
You can install it before or after the stock cooler. Its up to you, but personally I'd install it after the stock cooler.
In other words: tranny ---> stock cooler ----> aftermarket cooler ----> tranny.
Buy one with stacked plate (bar and plate) construction. B&M are stacked plate.
http://bmracing.com/index.php?id=pro...bcat=28&pid=73
Old 05-17-2006, 09:57 PM   #15 (permalink)
View marc780's Photo Gallery
I think 88le is right, that's the only way to plumb the fluid cooler.
If you were to plumb the aftermarket cooler first, it is just sending (air-cooled) fluid into the stock cooler (cooled by hot radiator water!) to get heated up some more and then to the tranny. Which mostly defeats the purpose of why you put the aftermarket cooler in the first place.
So you'd definitely need to route the hoses so the aftermarket cooler is that last one that gets the fluid i.e. right before it goes into the trans (if you want it to do the most cooling of the fluid.)
Transmission for 95 4runner w/90 engine Mallenski 4Runner Lounge 0 03-13-2006 11:55 AM
Camry V6 1999, 90K Service, traveling 1400miles camryv6man 3rd & 4th Generation (1992–1996 & 1997–2001) 5 02-03-2005 08:47 PM
