Check Engine Light - HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2006, 11:53 AM   #1 (permalink)
View toyotabob's Photo Gallery
3rd Generation Check Engine Light - HELP!
Just failed the California Emissions Test due to check engine light.
The code was P0500 Vehicle Speed Sensor Malfunction.
What is this? Is is possible to check myself, or must I pay $150 (the diagnostic fee the smog testing station quoted)?
Any help would be great.
Thanks
1996 Camry v6
Is there a simple way to reset the check engine light, or must I go to a technician?
toyotabob is offline   Reply With Quote
Old 05-15-2006, 12:15 PM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
Don't PAY!!!! Check the manual in the sticky section. It'll show you how to check your ECU.. If you need a better explanation than the manual offers, I'll be happy to help.
Lord_Anarchy is offline   Reply With Quote
Old 05-15-2006, 03:53 PM   #3 (permalink)
View netsfan549's Photo Gallery
Go to autozone tell them turn it off
netsfan549 is offline   Reply With Quote
Old 05-15-2006, 06:52 PM   #4 (permalink)
3rd Generation Check engine light continued
Check this out...recognized and repaired a problem with my ground cable (at the battery). After repair, no check engine light after the car is started. Is this normal...the mechanic at the smog check said the computer stores all alerted codes and transfers them to the Smog Check computer during testing. Is this true?
I asked the mechanic if I had made the repair (and thereby resetting the computer and correcting the ground problem) prior to getting my smog test, would I have passed. He giggled and said the computer would rat me out.
Help
Old 05-15-2006, 10:14 PM   #5 (permalink)
View foompla's Photo Gallery
youll be fine if you fixed it and the code is not current. there are no monitors for that.
foompla is offline   Reply With Quote
Old 05-15-2006, 10:18 PM   #6 (permalink)
Thank you foompla. I guess I will just have to monitor the problem...
By the way, what is the best diagnostic kit for the Gen 3 Camry? Would this be helpful in diagnosing this problem and others in the future?
Thanks tbob
Old 05-15-2006, 10:21 PM   #7 (permalink)
the toyota one works pretty darn well.
Old 05-15-2006, 10:48 PM   #8 (permalink)
5SFE
You can just use the jumper wire technique as per the manual. Much, much, much cheaper As far as the code, it remains in the ECU as the last code to force the light to come on but it doesn't mean crap. If you fail, the manual shows you how to reset the code so NOTHING is stored about the last error
Old 05-16-2006, 09:39 AM   #9 (permalink)
3rd Generation Cant find jumper reset instructions.
Please send location of the above mentioned procedure(jumper wire ecu reset)...I cant seem to find it in the manual (at the beginning of the thread listings).
Thank you very much for your help.
Old 05-16-2006, 12:40 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^^ 1MZ-FE is OBD-II, so the jumper trick (TE1 & E1) does not work.
"Skoolin' the unlearned!"
Old 05-16-2006, 12:46 PM   #11 (permalink)
5SFE
yeah.. Damn OBDII. When did the auto industry jump to OBDII, 96? Do all the IMZ-FE engine run on OBDII?
Old 05-16-2006, 12:49 PM   #12 (permalink)
Grenaded piston
88 LE's Avatar
Somewhere around there.
Yes.
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
Check Engine Light clp86rom Archived Corolla threads 13 06-17-2006 09:02 PM
