What's a bad water pump sound like??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2006, 12:42 PM   #1 (permalink)
View 89_3SFE's Photo Gallery
Can anyone tell me what a bad water pump sounds like??
89_3SFE is offline   Reply With Quote
Old 05-16-2006, 12:47 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Bad bearings are making noise similar to riding a skateboard on rough pavement
Doctor J is offline   Reply With Quote
Old 05-16-2006, 01:10 PM   #3 (permalink)
Dave's
Gameroom cash: $122050
View Dave's's Photo Gallery
Or it can sound just like a good one. There should be a little hole in the housing which should be checked for evidence of coolant leak. Think most will leak before the bearings go bad. (But there are always exceptions.)
Dave's is offline   Reply With Quote
Old 05-16-2006, 01:34 PM   #4 (permalink)
It does sound like a skateboard on rough pavement so I think it's the bearings. Also, antifreeze starting leaking really bad near where all the belts are. Does this sound like a water pump issue?
Old 05-16-2006, 01:45 PM   #5 (permalink)
Drifta89's Avatar
View Drifta89's Photo Gallery
Yeah that sounds like a water pump issue. My cousin's Galant currenty has the same issue. Its loosing coolant like crazy and the area under the water pump is dropping fluid. It hasn't been changed yet but its lookin like the pump is done.
07 I4 LE (fully unloaded except for free mats and cargo net!)
Personal add ons: alarm w/remote start, XLE Grill, Lip Spoiler, OEM Sport Pedals
93 SlowRolla (Speed Isn't Everything...ah who am I kidding?)
Drifta89 is offline   Reply With Quote
Old 05-16-2006, 01:46 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Most likely.
"Skoolin' the unlearned!"
Old 05-16-2006, 03:55 PM   #7 (permalink)
View Gary_602Z's Photo Gallery
Kind of like a wife!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 05-16-2006, 04:44 PM   #8 (permalink)
dsm = desert sand mica.
View 94dsm's Photo Gallery
3rd Generation
also, if your really low on coolant, it might make a diesel like sound. thats what happend in the case of my last car. and it will start to overheat real easily and you will loose alot of power followed by it just collectively and loudly breaking down...not pretty. it was a 94 linc conti.
catbacked. miles keep pileing up quickkk!
94dsm is offline   Reply With Quote
Old 05-16-2006, 07:34 PM   #9 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
yea that was the biggest noise maker in my car which i thought i was left with a junky car (95 cam 4banger) replaced the timing belt and water pump and noise gone
felonyr301 is offline   Reply With Quote
Old 05-16-2006, 08:03 PM   #10 (permalink)
Toyota Tech
View Kain's Photo Gallery
USA
u definitely have a water pump issue...replace water pump, t-belt, tension spring and refill with toyota long life red coolant and you shouldn't have a problem. Sometimes using other coolants in our engines can cause water pump failure.
Kain is offline   Reply With Quote
Water Pump Removal? justin04 Tercel, Paseo, Starlet, and Sera Forum 11 01-03-2006 11:10 AM
water pump location? fidnee Tercel, Paseo, Starlet, and Sera Forum 3 04-24-2005 05:06 PM
Noisey Water Pump 1998 Camry 4 Cylinder cdlubbe 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-13-2005 08:00 PM
1jz-gte water pump removal BCKLUP Hardcore Tech and Competition 0 10-08-2002 06:48 AM
