Cigarette Lighter (Element) Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2006, 01:35 PM   #1 (permalink)
View Maybrick2001's Photo Gallery
I have a '92 Toyota Camry in mint shape...only 34K on it. Of course the one thing that goes bad is the one thing that usually never goes bad...the cigarette lighter. I was told I had to replace the entire element.
I have looked high and low on instructions to do so...I already have the part...but have had no luck whatsoever.
If anyone can tell me what to do, if this is a difficult procedure (I installed a new radio and that seemed pretty easy), or if there is a link I could go to for instructions I would greatly appreciate it.
Thanks very much for any help.
James
Maybrick2001 is offline   Reply With Quote
Old 05-16-2006, 02:32 PM   #2 (permalink)
View 02whiteLE's Photo Gallery
34K on a '92? Why not save the money and just walk to work. Then you could have bought a nifty Zippo to go with your smoking habit.
I'm not sure, but I think that replacing it is a pretty simple unplug the old, plus in the new and you're done. Thats how it looked when I had the dash out in my car when I installed my XM radio.
'94 Camry LE. IDK, that minty green color that looks silver in a pic, until you see the car, and it's actually green.
02whiteLE is offline   Reply With Quote
Old 05-16-2006, 03:17 PM   #3 (permalink)
View newbie212's Photo Gallery
Check your fuses before you replace the element.. That was my problem
newbie212 is offline   Reply With Quote
Old 05-16-2006, 03:25 PM   #4 (permalink)
View Tarzan's Photo Gallery
I saw how it was hooked up when I replaced my radio. All you have to do is unplug the old one and plug the new one I assume. 34K on a 92? Did you get it from a grandma?
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 05-16-2006, 03:44 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
Isn't the element in the part that you pull out to light your smoke? Do like newbie212 said and check your fuses first.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 05-16-2006, 04:37 PM   #6 (permalink)
View CerialPhreak's Photo Gallery
Make sure you disconnect your batt before you do any work on it.
CerialPhreak is offline   Reply With Quote
Old 05-16-2006, 04:44 PM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yea it ain't hard to replace at all. Once you see how it looks you'll be able to figure it out.
http://www.xclusive.bz
Old 05-16-2006, 05:34 PM   #8 (permalink)
View enj1108's Photo Gallery
3rd Generation same issue
I have the same problem with my 92 camry. My cell phone charger just popped out ( it actually exploded into pieces!) one day and the lighter never worked after that. Where did you get the part from? As for checking the fuse; doesn't it share the same fuse with the radio? Or does it had it's own seperate fuse?
enj1108 is offline   Reply With Quote
Old 05-16-2006, 05:50 PM   #9 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $910527
iTrader Score: 59 reviews
Are you trying replace the socket or the element? I tried to take socket apart once, gave up..replaced the entire bezel with one from a junker!
Also if the radio works on a gen 3-3.5 the lighter fuse is fine!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 05-16-2006, 06:03 PM   #10 (permalink)
3rd Generation
I guess I need the socket then. It's that whole piece that's connected to back of the dash trim where the raido is located. I can't find it online. I looked at many toyota parts sites and search for cigarette lighter/ or just lighter and nothing matches.
Old 05-16-2006, 06:09 PM   #11 (permalink)
View infox's Photo Gallery
just go to the toyota dealer and ask for a printout of the part you need and how much it is, then you will see how much they want for it and also have the exact part # you need, just take the part # and plug it into google and you should be able to find something
infox is offline   Reply With Quote
Old 05-17-2006, 02:50 AM   #12 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
go to auto zone and buy one man the lighter element is like $6 i just replaced mine, it works good id guess but like 02whitele said nothing beats a zippo
ekim55121 is offline   Reply With Quote
Old 05-19-2006, 02:16 PM   #13 (permalink)
I got the part directly from the Toyota Dealership.
Old 05-19-2006, 02:16 PM   #14 (permalink)
Radio is working fine and I noticed on the specs that they run off the same line. Thanks.
Old 05-19-2006, 02:17 PM   #15 (permalink)
Cigarette Element
Thanks for all the help on this...much appreciated.
cigarette lighter not functioning in '96 Camry mwashbu 3rd & 4th Generation (1992–1996 & 1997–2001) 6 04-26-2008 01:56 AM
newbie with ipod and cigarette lighter ? lisamak 9th Generation (2003-2008) 8 11-04-2007 10:55 PM
replacing cigarette lighter kls Camry & Solara Lounge 4 08-30-2005 04:11 AM
Highlander: Cigarette lighter Problems JPNoble General Discussion 0 01-13-2005 07:39 PM
Cigarette Lighter popped out?!? SteelAvenger23 General Discussion 12 10-23-2004 07:36 PM
