Weird rubbing on a back right wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 02:39 AM   #1 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
4th Generation Weird rubbing on a back right wheel
Today my 97 xle started making this metal rubbing sound, but only on left turns, when car tilts to the right side. It's kind of metal sound, similar to a sound when brake pads go low and rub metal to metal when you press brake pedal, but in my case sound is alot milder. Plus car makes i only during left turns, brakes were checked a month ago and still brake without problem.
One spring snapped on a back left wheel maybe 2 weeks ago, but i don't think it's related to a rubbing sound since it started rubbing only today, and it shoudn't rub if it only occurs during left turns.
Anyone had this problem before????
CCCP is offline   Reply With Quote
Old 05-17-2006, 07:12 AM   #2 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
when you say, one spring snapped?
are you refering to the spring that resides on the stuts..?
it would be dangerous if that is the case!
skewe is offline   Reply With Quote
Old 05-17-2006, 07:35 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
if youre sure its not the brakes, maybe it the wheel bearing. does the sound have a pattern that matches the turning of the wheel and get louder when you increase your speed?
Old 05-17-2006, 10:22 AM   #4 (permalink)
drunken member
CCCP's Avatar
^^^ it's a constant scraping sound, which happens more often when speed increased in a turn, and becomes louder if a turn radius is shorter.
Will get my back breaks checked again tomorrow to make sure it's not a brakepad that went low or a heat shield.
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
About rear wheel hubs n bearings soccerman58 Tercel, Paseo, Starlet, and Sera Forum 30 10-05-2005 09:03 AM
BAd Experience Beware: GreenBay Tires 86B Feedback: Buyers, Sellers, and Vendors 4 06-08-2004 04:10 PM
Weird Creeking in Wheel Well Dark Camry & Solara Lounge 2 09-20-2003 02:59 PM
How to change steering wheel on a Gen2? Gen2RacerX 1st & 2nd Generation (1983–1986 & 1987-1991) 7 09-08-2003 02:31 PM
