This is what I've leared about the Auto Transmission. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 03:21 AM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
4th Generation This is what I've leared about the Auto Transmission.
[ L ] ===== The car only uses the 1st gear.
O/D off === No effect.
[ 2 ] ===== The car starts from 1st gear, then 2nd gear. Only 1st and 2nd gears are used.
[ D ] ===== The car starts from 1st gear, then computer determins which gear to use.
O/D off === Same as [ D ], except, the 4th gear won't be used.
Questions:
1) Are the above assumtions correct?
2) The car always starts from 1st gear, whether overdrive is on or off, correct?
3) When downshifting from [ D ] to [ 2 ], do I have to ease the throttle? Can I do the downshift while I'm still flooring the acceleration pedal?
P.S. This is the 2000 Camry V6 I'm talking about.
Thanks.
NewRacer is offline   Reply With Quote
Old 05-17-2006, 03:55 AM   #2 (permalink)
View TRDGen5.5camry's Photo Gallery
1. yes
2. yes
3. no cuz te tranny won't let you downshift from [D] to [2] you have to step on the brake and push the shifter button to shift to any gear.
The only one you can shift is 4th and 3th gear that it. You can shift to [2] if you froce it really hard it would in but you'll be braking something along the way. Don't know what but it will
david
TRDGen5.5camry is offline   Reply With Quote
Old 05-17-2006, 04:09 AM   #3 (permalink)
Okay, thanks. I have one more question:
4.) In a manual, when you are to pass the car in front of you, you always downshift from 5th to 4th. In this auto tranny, when I'm to pass, am I supposed to turn the o/d off before passing? Hence, achive the same effect in a manual.
Correct?
Old 05-17-2006, 04:16 AM   #4 (permalink)
View CamryXLE07's Photo Gallery
does o/d off give u more power than d shift? the new camry doesn't have o/d anymore, so i suppose the l substitute that o/d?
CamryXLE07 is offline   Reply With Quote
Old 05-17-2006, 04:17 AM   #5 (permalink)
Noob :-)
View ST185's Photo Gallery
4) Nope. Just floor it.
93 ST185
ST185 is offline   Reply With Quote
Old 05-17-2006, 04:21 AM   #6 (permalink)
yes you can but you'll wear down 3th gear faster then the other gears which mean that when ever the car up shift or down shift to 3th gear it might slip
david
Old 05-17-2006, 04:23 AM   #7 (permalink)
[D] and o/d off is the same it 3th gear and o/d on is 4th gear
Old 05-17-2006, 05:10 AM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Man you ask alot of questions about gears hahaha...i thought all this was answered in your other threads..
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-17-2006, 05:32 AM   #9 (permalink)
View leasaunce's Photo Gallery
Correct?
just step on the gas, let the car do its thing
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 05-17-2006, 07:41 AM   #10 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140895
since its an automatic, let it shift itself. if you want to shift gears yourself, you should have gotten a manual trans.
Old 05-17-2006, 08:14 AM   #11 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
with an auto you can floor and change gears all you want...no need to step on the brake to change from N to 1 and back.
Since it is an AUTOMATIC you can be going 60 mph or faster and slam it into 1 from D and the transmission will decide which gear it is safe to shift into, it will NOT shift into 2nd or 1st if you are currently doing 60+ mph. well...it might actually redline at 2nd...i forgot what my car did.
nodrogkam is offline   Reply With Quote
Old 05-17-2006, 08:49 AM   #12 (permalink)
Australian TN'er
View Phat Devil's Photo Gallery
the gen4 v6s rev limitor happens at 120km/hr (75m/hr) in 2nd gear auto.
Phat Devil is offline   Reply With Quote
Old 05-17-2006, 09:27 AM   #13 (permalink)
Camry LOVER!
View Azn_Stock_Camry's Photo Gallery
Originally Posted by TRDGen5.5camry
1. yes
2. yes
david
actually... i dont really agree to your answer to number 3. you dont have to step on the brake to downshift from [d] to [2]. and if your going from [L] to [2] you dont need to step on the brake. good job.
Azn_Stock_Camry is offline   Reply With Quote
Old 05-17-2006, 09:52 AM   #14 (permalink)
Embrace the Suck
Edmo83's Avatar
iTrader Score: 8 reviews
View Edmo83's Photo Gallery
4th Generation just drop the pedal
I completely agree, if your camry is well maintained and in decent shape engine wise, it should give you more than enough power to surpass a regular car....didnt help when i wanted to cut off a porsche carrera4 however, lol
92 SC300 Garnet Red 5-speed 119k
01 Camry LE V6 Sailfin Blue 95K miles
Edmo83 is offline   Reply With Quote
Old 05-17-2006, 10:17 AM   #15 (permalink)
View v6kamree's Photo Gallery
lol ive got what u call a quick shifter, im sure its dangerous but cbf fixin it. all i need to do is just push it up or down without pressin the button in to change gears. good when u want to change the gears urself but the auto changes at about 6500 anyway normally when u slam it so no point. like said by ghettosled above if u wanna change gears get a manual.
v6kamree is offline   Reply With Quote
Scrapyard in the GTA TdotTercel General Discussion 16 11-23-2011 03:18 PM
Auto Transmission Fluid Help... ptycamry Camry & Solara Lounge 17 09-01-2005 08:41 AM
XRS auto vs 6 spd Franko 1st Generation (2003-2008) 30 05-20-2003 09:41 PM
Redline auto transmission fluid ']['R][) camry Camry & Solara Lounge 3 06-26-2002 12:35 PM
