P to R very abrupt when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 09:30 AM   #1 (permalink)
Masturbater
View wimpwgn's Photo Gallery
Hello,
I have a 95 ES300, same as gen 3.5 Camry and I have a question regarding the auto tranny. When the car is cold, even after letting it warm up for a minute or two, it's always very abrupt to shift from P to R. However, after driving it for a while, shifting has always been smooth like butter. I notice high idle when the car is cold due to its design, is this what's causing the abrupt shift when the car is cold?
TIA
wimpwgn is offline   Reply With Quote
Old 05-17-2006, 10:02 AM   #2 (permalink)
View SuperGoop's Photo Gallery
How fast (RPM) was it idling when you shifted from P to R?
SuperGoop is offline   Reply With Quote
Old 05-17-2006, 10:03 AM   #3 (permalink)
Masturbater
Normal auto choke RPM, 1500-1800rpm. After shift to R, rpm drops to 800-1000, until engine fully warms up to normal 650-700rpm idle.
Old 05-17-2006, 10:39 AM   #4 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
I noticed it too on older automatic transmissions. If rpm's are high it will do it even on a brand new car.
CCCP is offline   Reply With Quote
Old 05-17-2006, 12:16 PM   #5 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Normal. Abrupt because transmission hasn't warmed up. Your engine might have warmed up a bit, but sitting there idling doesn't warm up your transmission really.
DarkMastyr is offline   Reply With Quote
Old 05-17-2006, 01:12 PM   #6 (permalink)
Masturbater
So everybody has that issue?
Old 05-17-2006, 04:03 PM   #7 (permalink)
bitch please
DarkMastyr's Avatar
It's not an issue. It's how it works.
Old 05-17-2006, 04:06 PM   #8 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
I know that was happening on my dad's Astro Van (haha the Pimp Van). All it needed was some transmission fluid. It changed dramatically, but then again there was still a noticeable jump from "P" to "R".
camryfour is offline   Reply With Quote
Old 05-17-2006, 04:16 PM   #9 (permalink)
Masturbater
Tranny fluid was drained and refilled 10k miles ago.
Old 05-17-2006, 04:42 PM   #10 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
It's perfectly normal... not only has the transmission not warmed up, but neither has the engine, and hence why its choke idling at 1500 or so RPM. So when your putting the transmission into a drive gear, the drop in RPM is greater, and hence you feel knock.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-17-2006, 05:31 PM   #11 (permalink)
Masturbater
Thanks for the reply.
I didn't feel that knock when the car was couple of years newer though.
2.2r Cold Start Problem redntanmiata 89-95 Toyota Pickup/Hilux 3 02-21-2006 07:52 AM
No power on cold startup saiklon MR2 Forum 1 10-05-2005 10:51 AM
AC Cold for 30 mins and then not that cold anymore ruoknow Camry & Solara Lounge 20 09-02-2005 07:49 PM
02 Highlander dies (idles really low) on cold starts... llkojakll 1st Generation (2001–2007) 3 09-01-2005 05:49 AM
Why does my heater turn cold after a little while???????? 89_3SFE Celica Forum 1 09-14-2004 01:05 AM
