NOS Kit Fried Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 11:07 PM   #1 (permalink)
View xsohaib's Photo Gallery
3rd Generation NOS Kit Fried Plugs
Well as per the helpful instructions from the forums, I (and my mechanic, a performance shop) were able to hook up the Zex nitrous kit properly.
I went for a test run on the 55 shot and everyhting seemed really well. Then on the way home even though I did not hit the NOS even a little bit, but the car started to misfire, and the transmisssion hunting for gears as if, and missing really bad, I tried to just get home (about a mile) but at this point the car shut off. The rpm fluctates and the car is running really really rich. My mechanic came in and checked the compression on the front three cylinders and he said they were perfect so assumed that the back three should be good too. When the plugs were taken out they were black and all burned out.
How can I rectify this problem. Is this something that would happen everytime I run NOS. Is there a permament solution.
Thanks
Sohaib
xsohaib is offline   Reply With Quote
Old 05-17-2006, 11:36 PM   #2 (permalink)
5SFE
Lord_Anarchy's Avatar
View Lord_Anarchy's Photo Gallery
Check your ignition system to make sure it's up to par and replace wires, rotor arm, and distrib. cap, if necesary.
Is that a dry shot of nitrous?
Lord_Anarchy is offline   Reply With Quote
Old 05-17-2006, 11:47 PM   #3 (permalink)
all stuff was new with under 5k miles replaced by toyota of Miami. The zex kit is a wet shot.
Old 05-18-2006, 04:23 PM   #4 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
you're plugs may not have been cold enough. what kind of plugs are they? What heat range are they?
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Noise Fix Kit for TRD CAI (Matrix/Corolla) blumatrix03 Car Parts for Sale 2 02-28-2007 10:06 AM
Wires, Plugs replac. dilema on 1MZ-FE fj40supraman Camry & Solara Lounge 9 09-30-2005 09:50 AM
Matrixw/Double Din Kit Installed TheGame7a Show & Share 13 04-05-2005 08:51 PM
Andys Autosport body kit cdmtrsprts Archived Corolla threads 0 03-11-2003 09:23 PM
91 V6 Wagon Body Kit advice HELP!! Stark77 1st & 2nd Generation (1983–1986 & 1987-1991) 9 04-29-2002 10:02 AM
