just a bit too much help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2006, 12:39 AM   #1 (permalink)
View P-Town Camry's Photo Gallery
4th Generation just a bit too much help
hey Guys i changed my oil on a 98 camry today but i filled it up just a little to much oil is that going to hurt the engine or what could happen
P-Town Camry is offline   Reply With Quote
Old 05-18-2006, 02:22 AM   #2 (permalink)
View Novice_cardude's Photo Gallery
How much over the 'safe' range on the dipstick? if it's only 1/4 of a quart over i wouldn't worry about it. Any higher and it's time to loosen the drain plug a bit. I've never overfilled a car in the shop but if I did, even a little bit, i'd be draining the excess out.
If you're really that worried about it just get it in the air again and drain some out...
Novice_cardude is offline   Reply With Quote
Old 05-18-2006, 02:31 AM   #3 (permalink)
View Sykon's Photo Gallery
I agree with Novice_cardude. There's a reason there's a full mark on the dipstick.
Sykon is offline   Reply With Quote
Old 05-18-2006, 08:22 AM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
try to let some out is all i can say. Ive gone about 3mm over the full line and thats fine but if its like 10mm...i'd DEFINATELY drain that out. you may actually be safer having the oil be inbetween full and low vs above full.
besides...your car doesnt burn the oil up so it wouldnt matter.
nodrogkam is offline   Reply With Quote
Old 05-18-2006, 02:51 PM   #5 (permalink)
Gameroom cash: $304355
I would say up to 1/2 quart overfilled should be OK. Any more and I would agree with draining a bit out. The engine is designed to have fresh oil sprayed on all internal moving parts by the oil pump. When a car is overfilled too much, the crankshaft actually sits in the oil in the pan and whips the oil in to a foam as the crankshaft rotates at high speeds. Foams contain air bubbles. Obviously, air does not lubricate as well as pure oil.
Mike
Bit the bullet and traded in the 05 base model for an 06 Ex cab SR5 power everything lotust 2nd Generation (2005+) 31 02-23-2006 07:54 PM
Something scared me a bit today... mwfromva 2nd Generation (2005+) 20 02-20-2006 05:25 AM
You know the bit about "Just broke in at 100,000 miles"??????? redgtxdi Camry & Solara Lounge 7 11-27-2005 02:09 AM
This made me feel a bit old... (about the 80's) CamryPunk Off Topic 55 05-05-2005 09:29 PM
A little bit of a brake.... -HiTMaN- Off Topic 1 07-11-2002 03:51 PM
