TRD struttower brace - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2006, 10:54 AM   #1 (permalink)
View camrykiller2's Photo Gallery
Gen5 TRD struttower brace
Do i need to torque down the bolts on my strut tower brace
camrykiller2 is offline   Reply With Quote
Old 05-18-2006, 11:20 AM   #2 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
hahahahah
u serious?
You'll like being blown
Bunthy is offline   Reply With Quote
Old 05-18-2006, 11:45 AM   #3 (permalink)
ha ha ha yes because i called trd to get numbers and they said it is not needed
so yes i am serious
Old 05-18-2006, 11:45 AM   #4 (permalink)
you know what if you dont have real info to give just mind your own
Old 05-18-2006, 12:24 PM   #5 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
You don't really have much of an option here. If TRD doesn't have any numbers for you, then just hand tighten it and use your best judgment. Well I guess your other option is to not tighten it at all...
DarkMastyr is offline   Reply With Quote
Old 05-18-2006, 04:16 PM   #6 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
I would guess whatever the torque value is for the upper strut mount nuts would be what you're looking for. Checking the repair manual that one our brothers linked us to states that the value would be 59 ft-lbs. Hope that helps.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 05-18-2006, 04:38 PM   #7 (permalink)
Bunthy's Avatar
lol, just kidding bro, take it easy.
I'm just saying, tighten it if they don't specify anything. At least you know its on tight. IF no figures are given, just tighten them tight its snug, then give it a 1/4 twist. good luck
Old 05-18-2006, 11:09 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I believe the strut mount bolts are 50-60 lb ft. They are 14mm and you will need a deep socket IIRC.
2007 Camry 2.4L 5M
Old 05-18-2006, 11:21 PM   #9 (permalink)
aka DA PROBLEM!
KILRCAM's Avatar
View KILRCAM's Photo Gallery
Just tighten them as far as you can take them. I did this with my 92 and when I get the bar for the 03 I'll be doing the same.
KILRCAM is offline   Reply With Quote
Old 05-19-2006, 05:47 AM   #10 (permalink)
View shots76's Photo Gallery
Hey, question here. I have a stock strut. You think a TRD strut bar will make any difference??
shots76 is offline   Reply With Quote
Old 05-20-2006, 06:55 AM   #11 (permalink)
Strut tower bar makes a little difference at the limit. I think the general consensus is that your money is better spent on a rear sway bar because that makes a lot more difference than the strut tower bar.
2007 Camry 2.4L 5M
FYI: Gen 5 TRD Strut Brace - Out of Stock Nationwide white3ch0c0late 5th & 6th Generation (2002-2006 & 2007-2011) 11 11-30-2005 01:10 AM
My review on TRD REAR Brace Wraith Yaris, Vitz and Echo Forum 3 05-10-2005 10:06 PM
