Camry with the manual transmission jerks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2006, 02:37 PM   #1 (permalink)
View Uhty's Photo Gallery
Gen5 Camry with the manual transmission jerks
I experience a really tough transition from deceleration to acceleration on my manual 2005 Camry. I try to pass it smoothly but it jerks, even shocks sometimes. It's worse when AC is on. I believe that it happens since the emission control system cuts a gas supply too sharp. Does anybody know how it could be adjusted? Thanks.
Uhty is offline   Reply With Quote
Old 05-18-2006, 02:57 PM   #2 (permalink)
View BobF's Photo Gallery
What speeds and gears are associated with this?
And just for clarity, this happens when you're slowing down while in gear and then you accelerate? If so, how hard are you accelerating?
Which engine do you have?
Bob
BobF is offline   Reply With Quote
Old 05-18-2006, 03:03 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Bob
the manual only came with the 2AZ-FE
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 05-18-2006, 03:08 PM   #4 (permalink)
Gen5
Bob
It happens on any gear, but essentially it's much more smoothly on the fifth gear when it's worst on the first one. It does happen when I slow down in any gear and then try to accelerate. I try to start my acceleration as smoothly as I can. Otherwise it really shocks. Same when I change gear - it's hard to match RPM exactly. As I've mentioned, it's worse when AC and/or cooling fans are on.
Old 05-18-2006, 03:19 PM   #5 (permalink)
Thanks! I did not know that.
Bob
Old 05-18-2006, 03:54 PM   #6 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
Do you have an CEL on? Try to check the engine for any hardware probs. > loose vacuum lines or something.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 05-18-2006, 03:57 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen5
Bob
no problem
Old 05-18-2006, 10:37 PM   #8 (permalink)
View marc780's Photo Gallery
On this new a car you would think it would be an engine issue as the other people are talking about. But its also possible it could be a broken engine mount causing this jerking?
Old 05-19-2006, 04:53 AM   #9 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
could be a cracked clutch my supra did that before the dammed thing just sploded, and took most of the motor with it, id prolly get it chekced out its still under the warranty, the best way to explain your problem is to TAKE the SERVICE MANAGER on a test drive if a service tech decides to call it a no fault or soemthing .
ekim55121 is offline   Reply With Quote
The Following User Says Thank You to ekim55121 For This Useful Post:
anotherYOTA (02-17-2012)
Old 05-19-2006, 08:16 AM   #10 (permalink)
Gen5
I have tested it with the service manager. They let me know that this happens due to to the emission control system operation. However, they don't want to change any emission setting although it's technically possible. It seems that I need to solve this problem myself.
Old 05-19-2006, 08:56 AM   #11 (permalink)
View 02whiteLE's Photo Gallery
Hopefully its not this obvious, but how long have you been driving a standard? If you're just learning, that could be your problem. If you're in 4th gear, and slow down to 20mph, while staying in 4th, it's gonna jerk when you try to accelerate. Same thing when changing gears. That's what it sounds like to me.
If you're a manual driving veteran, sorry for posting the obvious. It must be something else.
'94 Camry LE. IDK, that minty green color that looks silver in a pic, until you see the car, and it's actually green.
02whiteLE is offline   Reply With Quote
Old 05-19-2006, 11:23 AM   #12 (permalink)
Actually I was never driving a car with auto transmission. This one is my sixth or seventh manual car. For the last 5-6 years manual driving became more complicated since the emission control has it's impact. It cuts a gas supply during a shifting and deceleration. However, it shouldn't work so bad like in this particular car. All manual Camry's (I believe - all manual Toyota's) come from Japan with Japaneese gas in the tank. It's quite different from the American gazoline. When I've tested this car it worked good enough. It was changed dramatically after the first gas filling. I have also heared about the same problem from couple of more people.
I believe if I could slightly adjust the responsiveness of the emission control system it would work more smoothly. Unfortunately, dealer doesn't want to do that since they don't see it as a problem. I would do it myself if I'd know how to do that.
Old 05-19-2006, 11:28 AM   #13 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $590957
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Both US and Japan makes Manual Camrys. If yours have a removable foglight cap and tow hooks, it's from Japan. If not, it's a US bulit.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 05-19-2006, 11:44 AM   #14 (permalink)
Gen5
Well, it's even simpler - if VIN starts with J - it's Japaneese. American Camry's have VIN starting with 4. I am not aware about any manual Camry 2003-2006 built here. Not sure about 2007 model.
Old 05-19-2006, 11:50 AM   #15 (permalink)
FJ nut
View RAV4EVR's Photo Gallery
KOOL.... Another manual driver....
My thought would go to the GEAR your car is in if RPM high in smaller gear, the car is easily JERKABLE. I thought it was a DRIVER thing.
***** My love.... My dream.
RAV4EVR is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Toyota Camry autostart for Manual? dejacky Camry & Solara Lounge 6 07-07-2004 09:14 AM
