The 5S-FNE is the Compressed Natural Gas (CNG) variant of the 5SFE engine. An odd engine, different again to the Gas variant 5SFE. You may have a hard time finding one of these! Believe it was used in 1998+ Camry's and other Toyota's of the era.
Found this info from a quick Google search:
"Toyota started development of CNG powered vehicles back in 1984 and now has a range of commercial vehicles which use CNG. Toyota has also just released a CNG-powered, four-cylinder Carnry for limited volume sales to fleets in the USA with volumes planned to increase over the next two years based on continued research and development into the viability of CNG.
To overcome the traditional obstacle of limited range, Toyota has developed a special 135-litre CNG tank that can withstand 200 atmospheres of pressure.
Located in front of the luggage space this tank can store enough CNG to give the modified Carnry a cruising range of 350km on a single charge.
The tank is made from an aluminium-carbon fibre composite to reduce mass: when full, it weighs just 70kg. "
Read more here about Toyota's efforts:
http://www.aie.org.au/pubs/toyota.htm
