HELP: Headlamp bulbs changing. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2006, 08:14 PM   #1 (permalink)
'00 Camry V6 (1MZ-FE)
View NewRacer's Photo Gallery
4th Generation HELP: Headlamp bulbs changing.
I'm thinking to change the bulbs on the headlamps on my 2000 Camry V6. I read the owner's manual, it says there is a low beam bulb and high beam bulb. I looked at my car, there seems to be only two bulbs per headlamp.
What about the Day Time Runing light? Was that used in high beam? I know the low beam was on the other side.
Also any tips about changing the bulb. Last time I did it, I was very careful not to touch the bulb, and I didn't. But somehow I got it fogged up inside, so I'm so scared that I screwed up again.
NewRacer is offline   Reply With Quote
Old 05-21-2006, 08:32 PM   #2 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Whatever you do, be sure to note the exact way everything is placed in and you'll be fine. When I changed my road light this little springy metal thing that hold the bulb socket inside the housing made me swear my ass out until I took the cover off the other headlight to realize I needed to clamp it down and keep it pressed against the housing to put the screw back. Just a stupid thing took me 15 minutes too long...
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 05-21-2006, 09:22 PM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
DRL's are typically high beams powered with a lower voltage.
this should help:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Also, if you touch the bulbs, be sure to clean it off with alcohol before installing.
LE05 is offline   Reply With Quote
Old 05-22-2006, 12:25 AM   #4 (permalink)
Camry LOVER!
View Azn_Stock_Camry's Photo Gallery
is it possible to get hid's for the camry?
Azn_Stock_Camry is offline   Reply With Quote
Old 05-22-2006, 06:22 AM   #5 (permalink)
its possible, but it takes a little work to properly retrofit projectors into the headlights. never just use plug n play hid kits... you'll just cause massive glare to other drivers and it probably won't improve your lighting by much.
Sylvania Silverstars, I gotta admit... fredster34 Camry & Solara Lounge 17 04-01-2006 11:58 PM
Changing Gen 3 Climate Control bulbs. ARG! HELP!!!! ASG14 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-26-2005 08:12 AM
