Parking Light Voltage??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-21-2006, 09:52 PM   #1 (permalink)
View 99Camry99's Photo Gallery
4th Generation Parking Light Voltage???
Does anyone know how much voltage the parking lights run on? Not the headlights, just parking lights. Thanks
99Camry99 is offline   Reply With Quote
Old 05-21-2006, 09:53 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
all lights run on 12 V... you'd be hard pressed to find anything that isn't 12 V
LE05 is offline   Reply With Quote
Old 05-21-2006, 09:57 PM   #3 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
Maybe you are refering to the current? AMPs?
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 05-22-2006, 11:28 AM   #4 (permalink)
I bought a set of fog lights... http://cgi.ebay.com/ebaymotors/ws/eB...category=33709 Here's the link, but there was one wire that was supposed to be wired into the parking lights and I wired it to my fuse box instead. Then they didn't work, I checked the switch and the etch on the back was lifted and broken. So I drew too much maybe not voltage, current right? I need to find out the current/amps and so what the reading is on what I have it connected to. That's my issue. Any help?
Old 05-22-2006, 02:13 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Parking light wire is used to trigger a relay. There should be a relay included with the fog lights.
As for current draw, their rated 55W @ 12V. So its around 4.6 amps for each light or around 9.2 amps total.
"Skoolin' the unlearned!"
Old 05-22-2006, 07:56 PM   #6 (permalink)
The relay is fine, I know it works. Tested it on a different source outside of the car. Where should I connect the one wire that the directions told me to connect to the parking lights? I tied it in with a fuse but I think it drew too much and thts why my switch blew. Thanks for the help
Old 05-22-2006, 09:23 PM   #7 (permalink)
View Gary_602Z's Photo Gallery
Sure you didn't blow a fuse? Voltage is a push and amps are a draw (Visualize a garden hose the pressure would be voltage and the volume of water would be the amps). Hard to burn out a switch if it was the proper one for the system.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 05-23-2006, 04:56 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
To the parking light wire.
Brown plug that plugs into the back of the gauge cluster. Green wire.
http://www.cardomain.com/ride/748373/6
Tapping into a fuse = ghetto rigging.
I doubt the switch blew. You most likely have a blown fuse.
Tail Light Failure Sensor - NOT! driftinco 3rd & 4th Generation (1992–1996 & 1997–2001) 34 12-10-2011 04:13 PM
parking light bulb change for 94 1234567 3rd & 4th Generation (1992–1996 & 1997–2001) 1 05-20-2006 01:23 AM
CAMRY FAQ ***READ FIRST*** EKam Camry & Solara Lounge 7 07-08-2005 10:05 AM
92 Camry parking light replacement jwchen4 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-31-2004 10:00 AM
Convert parking light to a signal light. How? Phi General Discussion 5 08-18-2001 01:02 PM
