VSV cleaning? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2006, 02:22 AM   #1 (permalink)
View brnyrd's Photo Gallery
4th Generation VSV cleaning?
is it possible to service a VSV? im talkin bout my EGR VSV. the problem isnt with my EGR. so next step would be to check out my VSV. and after that, i have no idea.
the car idles and runs weird with everything plugged in. vacuum lines, etc. but when i disconnect the line from the VSV to the EGR valve, it stops idling rough, and evens right out. so im led to believe its the VSV.
any suggestions?
brnyrd is offline   Reply With Quote
Old 05-22-2006, 12:26 PM   #2 (permalink)
View marc780's Photo Gallery
Cleaning the EGR is worth a try, but if cleaning doesnt fix it, change the EGR. Also try cleaning your throttle body butterfly and IAC with carb cleaner.
Old 05-22-2006, 05:24 PM   #3 (permalink)
Damian
View damiankaren's Photo Gallery
EGR Sensor
If it has an EGR position sensor check that before you go disturbing all the EGR hardware. Check that the sensor resistance changes smoothly as you press the sensor pin in and out.
Hope this helps.
damiankaren is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
VSV location speedyts49 Celica Forum 13 10-16-2007 12:34 AM
vsv question *PIC* simplyxtrippin Camry & Solara Lounge 3 07-14-2006 12:23 PM
Wastegate or VSV problem? Mike@Fidanza MR2 Forum 2 05-09-2006 06:57 PM
Help with changing VSV evap purge valve Toyota-Guy Tercel, Paseo, Starlet, and Sera Forum 2 10-19-2005 11:21 AM
