internal engine cleaning.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2006, 05:10 PM   #1 (permalink)
View mike7869's Photo Gallery
i started running synthetic in my car after seeing the difference between the $1.05 and the $4.04 qt oils.. and i was wondering if there is anything else i can add to my oil here and there to clean up the insides like the cams and so on... oh and if i put a biger alternater will that cause any problems
mike7869 is offline   Reply With Quote
Old 05-23-2006, 11:56 AM   #2 (permalink)
View marc780's Photo Gallery
The only safe way to clean inside your engine with chemicals, is just to do a couple oil changes one after another.
Putting anything besides engine oil into the engine, is counterproductive in my view. If you add any kind of solvent, etc. into the engine, it is allowing the engine to run with poor lubrication (because solvent is NOT lubricating oil). And possibly creating more wear.
Old 05-23-2006, 12:18 PM   #3 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
My valves were making my engine sound like a '78 Ford pickup when I took off after freezing cold startups. Letting the engine warm up of course lessens the issue but I thought about cleaning up my engine with chemicals.
I figured I'd wait about 500km until my next oil change and drop some cleaner inside so it wouldn't stay as long in my engine but haven't done it yet, probably next oil change in about 1500kms if I don't read too many negative comments about it when searching forums.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 05-23-2006, 12:36 PM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
do not use any internal engine cleaner. it will loosen up crud and carbon inside of your engine and that crud could be whats keeping it from smoking like a freight train. it also cleans the metal so well, it washes the productive oil layers away from the metal and can cause scoring on start up. its just bad alltogether imo.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 05-23-2006, 12:37 PM   #5 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Use Gunk Out at your next oil change. Works fine.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 05-23-2006, 03:43 PM   #6 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
read up on using slight ATF w/ engine oil! I don't use it, but i've heard people mention it a few times.
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-23-2006, 03:53 PM   #7 (permalink)
The 6"4 Viking
Zandro's Avatar
View Zandro's Photo Gallery
I have tried AutoRx its certainly not snake oil, it removed all the tar in my engine.
I did check under the valve cover before i did the treatment, and a 1000km later
i checked again and all the tar was gone, a bit expensive yes but it works, those
engine flush products you use before your oil change doesn't do anything.
Zandro`s 09 Hilux 3.0 D4-D SR+
Zandro is offline   Reply With Quote
Old 05-25-2006, 11:54 PM   #8 (permalink)
jhbhatia, i am not fond of contradicting anybody, but plz DO NOt use ATF in your oil...! We ruined a $5000 engine at work because some one did this.
Old 05-26-2006, 12:20 AM   #9 (permalink)
2002 Camry
ToyotaToday's Avatar
View ToyotaToday's Photo Gallery
change the oil, drive it until oil is very hot. change the oil again. Best and safest way to clean the engine.
2006 4Runner Limited
ToyotaToday is offline   Reply With Quote
Old 05-26-2006, 01:32 AM   #10 (permalink)
2007 RED Camry XLE Owner
Old Dood's Avatar
View Old Dood's Photo Gallery
Motor Vac Carbon Clean
I had this done to two of my Buicks with the 3800 Serise II engine.
I get 3 more miles per gallon and it purrs!
http://www.motorvac.com/products/CarbonCleanMCS245.html
"We can't solve problems by using the same kind of thinking we used when we created them." Albert Einstein
Old Dood is offline   Reply With Quote
Old 05-26-2006, 06:12 AM   #11 (permalink)
View Dave G's Photo Gallery
A guy I knew went to one of those "Quick Lube" places and was talked into an "engine flush". Apparently it loosened up some old carbon deposits that ended up blocking his oil passage. Blew his motor.
Last I heard he was involved in a lawsuit to get them to pay for damages.
Dave G is offline   Reply With Quote
Old 05-26-2006, 12:10 PM   #12 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
I didn't say i use it, its something i've heard over the years. Some people use it. I just gave him an option (a tool) and did ask him to research himself. I've not done it myself and don't plan to do it..its just a suggestion. Glad you have better experience than me. Cus the oldies that worked on cars before the ecu's took over did add a little bit of atf. I'm not saying positive or negatives things...just pointing to another option!
Old 05-26-2006, 12:14 PM   #13 (permalink)
Old Dood's Avatar
The Motor Vac I am talking about is not one of those engine flushes......It is way more then that.
I would never go to a Quickie Lube.
This is where I have my Cars done at....www.denny'sautodiagnosis.com
They are very very careful on any machine they add to their shop. I am sold on the Motor Vac system...
Old 05-26-2006, 12:57 PM   #14 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
seafoam
WhiteRabbit is offline   Reply With Quote
Old 05-26-2006, 07:22 PM   #15 (permalink)
View bassthrive's Photo Gallery
Originally Posted by WhiteRabbit
seafoam
Great stuff. I put 1/3 in the crankcase oil, another 1/3 in through the brake booster, let it run for a minute and watch the white smoke come out the tail. Then I change the oil and filter right away, dump the remaining 1/3 seafoam in the gas tank and i'm done! Paid for itself in gained MPG.
now with 100% more clickability
bassthrive is offline   Reply With Quote
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Some new pics of my Camry - Engine Lighting Paint and Cleaning, + more (56k dont try) RedPhoenix Show & Share 29 05-31-2005 12:40 PM
Cleaning engine ~~ Den Hardcore Tech and Competition 3 04-01-2003 01:55 PM
