Originally Posted by Blackhawk3D
I know many will tell you to get a six, but a properly tuned turbo can do wonders, and even outpace the stock V6, plus it's lighter. To get max performance, you will have to have a custom manifold made up, but it will probably still be less expensive than a new front clip.
Not true... I did a v6 swap on my last car and that was incredible... the torque is right there, much more than with a standard turbo setup. also, if you turbo the 5sfe, the power may be close, or even pass the stock v6 by, with a ton of money, time and dedication. BUT if you swap in a 1mz, the power is there too, and it is RELIABLE. The 1mz is right around the same weight as the 5sfe. the 5sfe has an iron block and the 1mz has an aluminum block. the wieght saved there makes up for the extra couple cylinders. you dont need anything custom with a v6 swap. it is all factory bolt on parts.
BUT if you can get past that stuff and still want to turbo your 5sfe, then check the sticky at the top of the forum, how to turbo your 5sfe. OR cruise on over to
www.mr2oc.com their message board info about the 5sfe turbo convsersion is an invaluable resource.
